1 - 20 of 36 Posts
So my NOCTUA NH-u12P isnt coooling as well as it should. Could it be the cooler itself or could it be my bad TIM application or could it be the fan??
Originally Posted by slngsht View Post
yes.
try reseating it
yes what? and ill do that when i get my new memory cuz im going to be putting new thermal paste on my GPU as well.
ok. Well im thinkin about getting a new fan. Like a panaflo or Scythe S-Flex. Im also getting IC7 paste too.
fans dont make that big of a difference, a couple degrees thats it
That can be a big difference to some
Also to the OP, what is your ambient/room temperature?
Discussion Starter · #8 ·
yeah but that fan on it doesnt move like any air.
I would suspect it needs a reseat. It comes with a quality fan out of the box.
like 30 to 35c
Originally Posted by mocha989
like 30 to 35c
thats your problem right there, my room is like 25 C. An average room temp is 21 C
I TeK things...
Reseat it, and make sure you don't use too much thermal paste! That can hinder temps too!
anyways the fan that comes with the noctua is amazing
where you at that the temp is that high Florida?
like 30 to 35c
Well there's your problem, your room is WAY too hot.
My room temp is around 21C-22C.
A/C?
Discussion Starter · #18 ·
My Ambient temp right now is 33c according to Rivatuner. I live in Washington state of the U.S.A.
OMG thats 91 degrees Farenheit what the hell! It does not feel that hot it feels like 60 F.
I believe that's inside the case....what is your ROOM temperature, what does it say on the thermostat.
Discussion Starter · #20 ·
oh it says 66 farenheit
1 - 20 of 36 Posts
