1 - 6 of 6 Posts
My creative headphones have partially died and the battery life wasnt great anyway so time for new gear.
I was thinking of getting Sennheiser PXC450 headphones for travel.
Any experience with these? Any recomendations?
phenomenal swag
I would recommend the Ultimate Ears Triple.fi 10 IEM's.
http://www.amazon.com/Ultimate-Ears-TripleFi-Isolating-Earphones/dp/B0019RBJOE/ref=sr_1_1?ie=UTF8&qid=1317837159&sr=8-1]Amazon.com: Ultimate Ears TripleFi 10 Noise Isolating Earphones: Electronics[/URL]
I own these and they're great. I just find IEM's better for travel. The sound quality is great and any review will tell you that. Some people have reported fit problems with these, though. I have smaller than average ear canals and the smallest set of rubber tips (the IEM's come with multiple sets of tips, including a set of Comply Foam tips, to get the best fit) works well for me. There's also a piece that wraps around your ear, which works well for keeping the IEM's in place.
Thanks I shall look into all the options provided.
Edit: I should add these will be for travelling on long flights, watching movies and music more so than gaming. Great noise cancelling is a must.
I don't think you need something like the PXC450. I would just choose something with good isolation such as the Audio Technica A900s or Sennheiser HD 25-1 II
1 - 6 of 6 Posts
