1 - 6 of 6 Posts
I have this great PSU since 2008 but it's fan is getting noisy so i'm searching a replacement...<br><br><br>
This is the stock fan, an <b>ADDA AD1212HB-A71GL</b><br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2119583/"><img alt="" class="lightbox-enabled" data-id="2119583" data-type="61" src="http://www.overclock.net/content/type/61/id/2119583/flags/LL" style="; width: 500px; height: 493px"></a><br><br><br><b>Specs</b><br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2119584/"><img alt="" class="lightbox-enabled" data-id="2119584" data-type="61" src="http://www.overclock.net/content/type/61/id/2119584/flags/LL" style="; width: 1675px; height: 63px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2119585/"><img alt="" class="lightbox-enabled" data-id="2119585" data-type="61" src="http://www.overclock.net/content/type/61/id/2119585/flags/LL" style="; width: 1672px; height: 33px"></a><br><br><b><br>
The replacement fan <span style="text-decoration:underline;">needs to be a Noiseblocker model</span> so which model would be the best option for noise/performance?</b><br><br><br><br><br><span style="color:#FF0000;"><b>NB-Multiframe® S-Series 120mm</b></span><br><br>
<a href="http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-multiframe-series/120x120x25mm.php" target="_blank">http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-multiframe-series/120x120x25mm.php</a><br><br><b>M12-1 750rpm 3 Pin 6.0 V / 12.0 V 8 dBA 58.0 m³<br>
M12-2 1250rpm 3 Pin 4.5 V / 12.0 V 16 dBA 87.0 m³<br>
M12-3 1800rpm 3 Pin 4.5 V / 12.0 V 27 dBA 124.0 m³<br>
M12-P 2000rpm 4 Pin (PWM) 4.5 V / 12.0 V 29 dBA 133.0 m³<br>
M12-PS 1500rpm 4 Pin (PWM) 5.5 V / 12.0 V 23 dBA 100.0 m³</b><br><br><span style="color:#FF0000;"><b>NB-eLoop® Series 120mm</b></span><br><br>
<a href="http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-eloop-series/120x120x25mm.php" target="_blank">http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-eloop-series/120x120x25mm.php</a><br><br><b>B12-1 800rpm 3 Pin 5.4 V / 12.0 V 8 dBA 57.3 m³<br>
B12-2 1300rpm 3 Pin 3.4 V / 12.0 V 17 dBA 86.9 m³<br>
B12-3 1900rpm 3 Pin 3.4 V / 12.0 V 27 dBA 121.2 m³<br>
B12-4 2400rpm 3 Pin 3.3 V / 12.0 V 34 dBA 150.3 m³<br>
B12-PS 1500rpm 4 Pin (PWM) 6.2 V / 12.0 V 21 dBA 98.7 m³<br>
B12-P 2000rpm 4 Pin (PWM) 6.0 V / 12.0 V 28 dBA 132.</b>4 m³<br><br><span style="color:#FF0000;"><b>NB-BlackSilent Pro 120mm</b></span><br><br>
<a href="http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-blacksilent-pro-series/120x120x25mm.php" target="_blank">http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-blacksilent-pro-series/120x120x25mm.php</a><br><br><b>PL-1 900rpm 3 Pin 4.5 V / 12.0 V 12 dBA 68.0 m³<br>
PL-2 1400rpm 3 Pin 4.0 V / 12.0 V 23 dBA 96.0 m³<br>
PL-PS 1500rpm 4 Pin (PWM) 6.0 V / 12.0 V 24 dBA 100.0 m³</b><br><br><span style="color:#FF0000;"><b>NB-BlackSilentFan 120mm</b></span><br><br><br><b>XL-1 1000rpm 3 Pin 5.0 V / 12.0 V 13 dBA 69.0 m³<br>
XL-2 1500rpm 3 Pin 4.0 V / 12.0 V 24 dBA 98.0 m³<br>
XL-P 2000rpm 4 Pin (PWM) 4.5 V / 12.0 V 31 dBA 128.0 m³</b><br><br>
<a href="http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-blacksilentfan-series/120x120x25mm.php" target="_blank">http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-blacksilentfan-series/120x120x25mm.php</a><br><br><br><br><br><br>
thanks !
Try to keep it around the same or higher cfm, and nice low noise (DB), looking at your old one it´s putting out 85.2 cfm, also you want to look at keeping the wattage as close as possible.<br>
My choice would be this one.<br>
You could probably just get away with lubricating the bearings if you wanted to , there´s a great guide <a class="bbcode_url" href="http://www.overclock.net/t/773256/prepping-a-sleeve-bearing-fan-for-work">here</a> if you want to have a go.<br>
edit ; Does it still have warranty ?
<div class="quote-container" data-huddler-embed="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22650994" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>mr soft</strong> <a href="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22650994"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
M12-2 1250rpm 3 Pin 4.5 V / 12.0 V 16 dBA 87.0 m³</div>
</div>
<br>
Why would you prefer that model ?<br><div class="quote-container" data-huddler-embed="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22650994" data-huddler-embed-placeholder="false"><span>Quote:</span>
You could probably just get away with lubricating the bearings if you wanted to , there´s a great guide <a class="bbcode_url" href="http://www.overclock.net/t/773256/prepping-a-sleeve-bearing-fan-for-work">here</a> if you want to have a go.</div>
</div>
<br>
I prefer to change the entire fan because i can get if for free...<br><br><div class="quote-container" data-huddler-embed="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22650994" data-huddler-embed-placeholder="false"><span>Quote:</span>
Does it still have warranty ?</div>
</div>
<br>
No.
Because I hate noise , anything over 1300 rpm for me is noisy , it´s also the closest for CFM which is important to keep a similar or better airflow over the components. You could go up to 18 - 20 DB with a higher cfm if you want to be sure , just watch the Start/nominal voltage, I think if you keep it at 4.5 you should be OK.<br>
It might even be worth writing a quick email to corsair to check that last point.
Discussion Starter #5
<div class="quote-container" data-huddler-embed="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22651136" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>mr soft</strong> <a href="/t/1505284/noiseblocker-fan-for-a-corsair-hx520/0_20#post_22651136"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
it´s also the closest for CFM which is important to keep a similar or better airflow over the components.</div>
</div>
<br>
85cfm vs 51cfm (87 m³h) ...<br><br>
So i would need around 140 m³h to get the closest to the original fan.
Yes mate , I missed the m³ damn imperial / metric<br>
maybe this one with slightly less CFM .<br><br>
M12-P 2000rpm 4 Pin (PWM) 4.5 V / 12.0 V 29 dBA 133.0 m³<br><br>
Your fan will probably never get up to full speed anyway, unless you have poor case flow, high ambient temps, and your seriously overclocking .
1 - 6 of 6 Posts
