Nokia 6300 Not turning on?
31870 42
Hey guys.
(I have googled for this problem but nothing seems to help...)
I got myself a Nokia 6300... and I turned it on last night, no problems.
I then connected the USB to PC and transferred songs, pics ect.
Then the battery went flat, and the phone turned off.
So I left it on the charger last night and woke up this morning.
I went to turn it on, but nothing happened.
I pressed every single key on the phone, even held them in... but NOTHING happened.
So I took the battery out, and put it back in.
The lights on the side lit up, but nothing else happened.
Once again, I try pressing and holding every key on the keypad.
But nothing.
So at the moment, the SIM and battery are out, and if I put em back in, the only thing that happens is the lights on the side light up...
Can anyone help?
1 - 20 of 43 Posts
maybe you added a bad file.. no good, do you have another Micro SD to try?
Originally Posted by sktfreak View Post
I can't connect the phone to PC via USB even, because it ain't turning on.
hy,
in fact your solution is to reflash the phone in "dead usb mode"(if not hardware damage)
but more sure via f-bus cable ==> better go with in a shop
P.S: if need help to try with usb then I will post procedure ....
br,
Freezzby
Discussion Starter · #13 ·
Originally Posted by Freezzby View Post
hy,
br,
Freezzby
Tell me the procedure, please. It would be great =)
Rep++
Discussion Starter · #15 ·
look to your pm
when your ready pm me please for part 2
br and hope to fix your phone,
Freezzby
You are THE best!
My phone is now fixed.. OMG!!!
I love you, thank you so much =)
hy,
can you please post what is the problem with the phone
I need more details
and what you tried to do(have you tried to upgrade or flash the phone to fix??) because if you search with your best friend google ....
but post here more details and I will try to help you
hi,
Last Sunday morning the phone (Nokia 6300, bought in jun 2008) worked. Sunday in the afternoon I discovered that the phone has shut down. I tried to turn the phone on again by pressing the on/off button. The the phone did not turn on. If I press the on/off button, the blue lights at both sides of the phone light up, nothing else happens.
I tried to push the on/off button for 1 and seconds. Removed the sim-card and tried the same. Removed also the micro SD and tried the same again. Removed the battery, charged the battery, etc... No improvements at all. Up to now the only thing that happens is that the blue lights at both sides of the phone light up as long as I press the on/off button.
ok sorry for the long time of wait
need to flash the phone and hope its ok
I will send you "How to"
if need to reply or ask me something its better to PM me like this I see your PM when I look to my mails because don't connect every day here
br,
Freezzby
1 - 20 of 43 Posts
