Originally Posted by spookedjunglist did yiou try the stock heatsink with yours?? if so is your spark 7 better? i have the same sp7 and a 3.2e dont know if we share the same oem heatsink though heres a pic of it |
Originally Posted by mfillpot The Stock HS sucked worse than this SPark7+, but the SPark is better than the aquarius II i was using. I am just waiting for the OK from my wife to get the XP-90. As for accessing the configuration, how do I get into the area were I can type "-config"? |
Originally Posted by spookedjunglist you should be able to right click on the little cog/protien looking thing in the bottom right and select configure then under advanced step down the CPU usage percent slider my core was running like 130°f untill i modified the setup how is the spark7 better than the aquarious 2 ? |
Originally Posted by mfillpot The aquarius II is a piece of crap, the pump died, the hoses are not thick enough for sufficient flow, the waterblock did very little and the radiator barely cooled the water, I am pulling slightly better tems with the $25 Spark7+ than I did with the $150 Aquarius II system. Edit: I think I found the problem with the folding app, I had two of the non-graphic versions running at once. I will post again if the problem continues. |
