Noob About to Order...
581 Views 17 Replies 10 Participants Last post by  Drackula2000
You've all been pretty helpful with my previous posts and as a result this is the list of components that I am about to order.
CPU = Phenom II 940
Motherboard = Gigabyte GA-MA790X-UD4
Graphics = Sapphire HD 4850x2 2gb
Ram = G.Skill DDR2 4G(2x2G)PC8500 1066Mhz Heatspreader
Hard Drive = Samsung 500gb 7200rpm
PSU = Corsair tx750
OS = Vista Premium 64bit
Case = Well I wanted a Thermaltake Armor+ VH8000BWS Mid tower but I am scared the hd 4850x2 will not fit. If someone has achieved this setup please let me know.
Now I am stuck between the Full size Thermaltake Armor+, or the Thermaltake Swing Rs100. Any Suggestions?
Anyone want to suggest any changes/upgrades/downgrades? I don't really have a particular budget I am just going for value for money components and something that will be futureproof (for the next 5-6 years).
Thanks
1 - 18 of 18 Posts
Size of graphics cards that will fit. And the gfx card is 11.1 inches long. So I don't think it will fit from my understanding of what is on the manufacturers site. Also you can get some great deals on the Armors form the Thermaltake B-Stock store
Not sure why you are getting a 4850x2, nor why people are recommending them.
Shoddy, proprietary drivers; extra long length; and only manufactured by a single (bad) company. If you ever break your card, you have to pay a $35 resocking fee, AND ship the card both ways.
I'd say go with either a 4850 crossfire solution (same performance, except you get graphics redundancy. If the 4850x2 breaks, no GPU for you. If a 4850 breaks, you still have an extra.)
If you don't want dual cards, a 4870 1gb is more than enough performance for most people, even enthusiasts. It will run Crysis on high settings without pitching a fit, and it has support from official drivers.
For your HDD, drop the 500gb Samsung, and pick up a WD6400AAKS or WD6401AALS (AALS has 5year warranty, AAKS has 3 year). Both of those two drives have performance similar to a WD Raptor 10k drive, due to their dense triple-platter design.
Also, if you pick ANY other card, and I stress ANY, you will not have a problem trying to fit it into a Armor case.
I can see the logic here.
I was going the 4850x2 because it seemed to be the thing to do based on all the hype i've read. However, If I am going to go a single card then is the 4870 really the way I should be going? I've put all my focus into the 4850x2 and know nothing about any other cards to suit my system.
Yeah I would personally go the 4870 1gb route you can get one for just under 200 on the Egg and be good to go for a long time.
The only 1gb 4870 I can find is the Sapphire HD4870 1G GDDR5 PCI E TVO.
Is this the one we want?
The card is so new, thats the only reason. One company picked it up, because they saw potential, ATi didn't, and sold the rights to ONE GFX card maker company.
A buddy of mine had his for a month, loved it to death! Sold it, because he quit gaming, but a very nice card! If you do get it, get the 4850X2 2GB model, very nice!
I believe you may want to see the whole list of 4870 1GB cards here at the egg. However, according to what drakan posted, you may want to sway away from Sapphire cards (even though it's the cheapest without mir).
I am NOT trying to start a flame war here, honest.
But since the OP is a n00b I figured I would add this:
For the most part, Intel makes faster processors that are easier to overclock than AMD. The phenom II's are certainly nice CPUs, but do some long and hard research before deciding on AMD in the present market.
This is coming from someone who has owned both and who doesn't swear a silly allegiance to a corporation.
If you are low on cash, might I suggest a P45 mobo + e7200 processor.
If you want to go quad-core, I suggest a P45 mobo + Q6600 or Q8200.
Either way, you are likely to get better performance out of the box, and have a hell of an easier time overclocking.
Again, though, the Phenom II's are solid hardware. Just be sure to do some research before allowing the fanboys on here to dictate your purchasing decisions.
sheeesh for the same price, an equivalent amd system will pawn to death any intel build.
and you'd have to be a complete idiot rather than a noob if you think that the new amd cpus are very hard to overclock coz it's so untrue.
i don't friggin' understand why the heck would you have to suggest one, when it's clearly enough that the op wants an amd system. now go back to your own nest. don't start now
to the op, sapphire is good brand if you take care of their products well, to avoid rma. otherwise, go something like visiontek, xfx and asus.
Pointless Post IMHO^^^
The majority of that post is based off of your opinion. The 2 main things that I disagree with in your post is that the general speed of intel being faster than amd, and the overclock difficulty of AMD. Intel chips may overclock higher, but the process of overclocking is definitely easier with AMD (especially with their black editions). Phenom II's are also just as fast, if not faster, clock for clock as the chips that you have mentioned.
Anyways, I think your setup is good, maybe change the GPU as others have said.
Yeah, I'd go with the 4870 1GB. The XFX looks nice, but I doubt you could really go wrong with any brand. Also, the Phenom II is going to be great. I bought my Q9550 nearing nine months ago now. If I were buying today, I'd have a hard time picking a C2Q over a PII. They're pretty even, and I think I'd rather support AMD.
Relax there sparky. When I built my first build I was going to install a Pentium 4 @ 2.4GHz because I thought it was the fastest. I posted on a forum, and someone turned me on to the idea of an Athlon 64, and I was sold.
I have plenty of AMD systems. I also have plenty of Intel systems. I don't have allegiances to giant multi-national corporations that don't care about me. I buy whichever product is better, given my price range.
Here, it's at least adviseable that the Intel chips are a bit faster. It's nice that you like AMD, and you have fun with them. That's great. But they simply are not faster. Phenom II's, clock for clock, will rival a 65nm Core 2. BUt the 45nm Core 2's overclock much better, not to mention the Core i7's.
I really don't want to start a flame war. I obviously like AMD -- that's why I was reading this forum. But to say that I should go back to my "nest" for telling someone new to look into other options is asinine. Not to mention the fact that what I posted was, for the most part, pretty accurate.
I would get a GTX260 c216 over a 4870 IMO. It seems to beat it in most tests and can be had for slightly cheaper now.
http://www.newegg.com/Product/Produc...82E16814150329
his 4870 1 gb gddr 5 $194 on tigerdirect just crossfire it
ps put the fan on manual and set it to atleast 60% the sucker runs hot I dont know whos the dork that programmed the fan to run at 20% on default
Great.. Thanks to all of you, even the intel guy. Unfortunately Newegg does not ship to Australia so my only real options are as follows:
ATI 4870
Asus EAH4870 HTDI 512M RV770PRO DDR5 PCIE2.0 DVI HDTV HDCP Instock $365.00
Asus EAH4870-DKHTDI512MD5 RADEON 4870, 512MB, DDR5 Instock $375.00
Gigabyte R4870X2 2G R700 DDR5 PCIE2.0 DVI HDTV HDMI Instock $799.00
Hightech ATI HD4870 IceQ4 Turbo (Overclocked) PCI-E 2.0 1GB PreorderETA $413.00
Sapphire HD4870 1G GDDR5 PCI E TVO Instock $398.00
Sapphire HD4870 512M GDDR5 PCI E TVO Instock $344.00
NVIDIA 260GTX
Asus ENGTX260 896meg 448Bit DDR3 Dual DVI HDTV Instock $419.00
Gigabyte GTX260 896M OC DDR3 PCIE2.0 2xDVI TV-Out HDCP HDMI Instock $422.00
Leadtek GF GTX260 Extreme PCI-E2.0 896MB Instock $405.00
Leadtek GF GTX260+ (216SP) OC PCI-E2.0 896MB DDR3 NVIDIA PhysX Ready Instock $419.00
Zotac GF GTX260*2 896M DDR3(FarCry2 include)216SP Instock $420.00
Zotac GTX260 AMP2! 896MB HDMI(GRID Include) Instock $469.00
So which of these would be my best bet? Cheers
c2d MUCH BETTER than a ph2 in overclocking? what is this just based on some review sites with a multi oc with an increase in voltage without tweaking the rest? come on now. you can't even compare a $200 intel vs $200 amd simply because there's no contest. if you want an equivalent performing intel cpu for amd's $200, you'll have to pay $50 and so. and considering that amd chipsets are cheaper and are better than any lga 775 chipset.
oh the i7 is a different story. and it's the only chipset that i would consider over a ph2.
edit:
to the op, since your mobo is not an nvidia chipset, go with ati.
if you just buy it from your local store, get the 1gb sapphire and check for issues. you can easily have it replaced since it's just at a local store. if not, go for the his iceq. they're good at ocing.
if you plan to fold, then go for nvidia. get the asus one.
Looks like that is your best option. Does the site you would be getting this from have a good return policy?
1 - 18 of 18 Posts
