1 - 6 of 6 Posts
I've just purchased an Asus GTX 660 Ti DirectCU II and want to safely overclock it, Is there any specific software i should use?
Use EVGA Precision or MSI Afterburner.
I've heard some bad things about ASUS Tweak, but I've never tried it and don't see how it would be any different.
Thanks for the response I have just tested afterburner with the +100 core +200 mem and found an increase of 5fps with Heaven Benchmark 4.0, I'll try increasing the clock speeds by 10MHz each test and see what my max is.
is Kombustor any good?
Kombuster is good. Next step is ofcourse unlocking your bios for more voltage. Any questions simply ask
Discussion Starter · #6 ·
I've managed to do some good overclocking using MSI afterburner currently set like this -
Core voltage default
Power limit % 110
Core clock +110
Memory clock +300
Fan 100%
Thanks for the advice
1 - 6 of 6 Posts
