1 - 7 of 7 Posts
Is it normal for the +12v to drop to 11.827v or as low as 11.772v while gaming?
Also is it ok for the +5v to go up to 5.064v? Here is a pic of what I am talking about. all the info is in the ASRock utility
I am thinking about ordering a CORSAIR 650TX http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Would that be enough to power my signature rig + a 9800Gt for Phyx and maybe 2 more 120mm fans?
I drop even lower than that when folding on both CPU and GPU (11.65V)
and I'm still fine
You're good down to 11.4V (i.e. within ATX 5% standards)
5.064V is also perfectly fine
~11.7v isn't terrible, but thats also not great voltage regulation... and for the price of the 650TX, you might be able to find a better unit. the Antec Neo Eco 620w for example. ($69)
Ok good, I am still thinking about that Corair P/S so I can add 2 more fans ( would be 7 total including the 2 on the H50) and the 9800GT for Phyx, would it be a good choice? This crappy BFG is dual 12v rails @ 18 amps each (404w total 12v) which seems a little weak running all my stuff. Oh and I have a 500GB USB3 hard drive running off of my computer also, I don't want to have my stuff blow up on me
the 650TX isnt a bad unit. i like the Antec Neo Eco 620w more. there are some seasonic units, but thats where the price is going to go up
Not new to Overclock.net
It's actually enough power.
But regarding those voltage readings: try to avoid trusting software to read those voltages.
But if you really want to replace the PSU, then make a new thread in the Power Supplies forum and have at it.
1 - 7 of 7 Posts
