1 - 11 of 11 Posts
Hey all got my self a FX8120 and im really happy with the performance (upgraded from Core2Quad 8300)
Only got one issue and thats my temp's the thing give's of no heat what so ever ???
My min temp is 5 Degrees and max is never over 26 degrees is this normal ??
338
High Clocker
Core temp is wrong unless its underful load (prime)
Also you have cool & quite enabled which underclocks it to make it run cooler and use less power.
I have not over clocked my cpu yet. I am running the very slight OC that my MSI motherboard has. Its running 3.3ghz. Here is where my temps are. I am running a corsair H60 cpu water cooler.
Here is a screen shoot just after I ran 3d mark vantage so you can see the temps at idle and how hot mine gets.
375
Hey again i used prime 95 for 3 hours last night and got 34degrees max and now it wont drop under 7degrees
Im just really shocked at these low temps lol
Will it affect my Cpu life if i disable cool and quiet i have a good cooler ??
Thanks for the help
Originally Posted by Brummy182 View Post
Yeh i was thinking that
I don't plan on overclocking it yet anyway not until i meet something it wont run
This is exactly how I see it. As a gamer if this CPU is running all the games I play on max settings with 60+ fps then I see no reason to OC it..... yet!
1 - 11 of 11 Posts
