Upping the CPU/NB doesn't give that much of a performance boost from your current settings.
However you could try playing around with FSB?
CPU/NB limitations may be due to the internal clock however you could push it further by increasing the bus speeds along with your current settings.
Increasing the bus speeds and also the multiplier can gain higher frequencies as well as an overall performance boost in other areas of the system.
