1 - 20 of 22 Posts
... well not quite. Seeing as I'm @ 458FSB, I had a bit of free time today and decided to crack my case open to see how my new heatsink was doing... no problems there.<br />
<br />
However, I can't touch the northbridge heatsink for longer than 1 or 2 seconds before I feel my finger burning.<br />
<br />
1- Is this a problem, or quite common?<br />
2- Look at the picture below:<br />
<br />
<img src="http://img45.imageshack.us/img45/9459/img0027ow4.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
As you can see, the Arctic Cooler Freezer 7 Pro is "overlaping" the NB heatsink.... I've seen people do some mods by placing a small 40mm fan on it, but I was hoping for something a little more... long term.<br />
<br />
On the left of the picture would be my PCIe Grahpics card (not shown) and at the bottom are the RAM slots (partially shown). Bear in mind that this picture was taken @ an angle, and there isn't much more than 3cm to the left before hitting the GFX card.<br />
<br />
<br />
So, should I worry about it, or is this not the end of the world. I'm happy to buy a NB heatsink, but honestly don't feel like taking the mobo out (would I have to?, is it hard to install?)<br />
<br />
Thanks for your advice,<br />
<br />
Jimmy
Well If you have a temp probe you could find what the actual temp is. I believe they can get pretty hot but you should try to find the actual temp before doing anything else
If you decide to put active cooling on it this is a good one... <br />
<a href="http://www.svc.com/mcx159-cu.html" target="_blank">Swiftech MCX159-CU Extreme Duty All-Copper Heatsink w/ 40mm Fan</a>
It should give the temp in BIOS. As long as its not above 60C it should be fine.
Discussion Starter #5
I don't have a temp probe, and I've never seen temp information in the BIOS. Finally, as can be seen in the picture, I need a smallish NB heatsink... or maybe something like the HR-05, but placed facing the CPU cooler (as opposed to facing the back of the case).
Maybe one like this ....<a href="http://www.svc.com/hr-05-sli.html" target="_blank">Thermalright HR-05-SLI High Riser SLI Northbridge Chipset Cooler</a>
Starting to become a BOFH
The TT NB HSF. I dont know what it's called, but it is gold.
<tr>
<div>
Originally Posted by <strong>atomicfission92</strong>
</div>
<div style="font-style:italic">I would just get a 40mm fan and place it on top or on the side of it. Just something to get some air moving across the cooling fins</div>
</td>
</tr>
</table>
</div><br />
Yeah, just slap a 40mm fan on it. Also, if you already haven't done so, yank the stock HS off the NB, clean all the gunk off and use a little AS5 and reapply the HS. Between that and a fan, you should see a big improvement.
The NB on the DS3's are known to get hot past 450 FSB.
<a href="http://www.overclock.net/faqs/125716-how-attach-fan-your-north-bridge.html" target="_blank">http://www.overclock.net/faqs/125716...th-bridge.html</a>
<tr>
<div>
Originally Posted by <strong>FrankenPC</strong>
</div>
<div style="font-style:italic">Yeah, just slap a 40mm fan on it. Also, if you already haven't done so, yank the stock HS off the NB, clean all the gunk off and use a little AS5 and reapply the HS. Between that and a fan, you should see a big improvement.</div>
</td>
</tr>
</table>
</div>Yeah this is what I would do if I were you. Also remember that by "improvement" he means chip temp, not heatsink temp. After you change the paste the heatsink will actually get hotter but that's good because it means more of the heat is being transfered away from the chip into the heatsink.
Discussion Starter #13
Alright, sounds like a plan... now I have to go buy small 40 MM fan though! I have some zipties and some string, I'll see if that will help...<br />
<br />
Is it easy taking off the NB heatsink?
yup its pretty simple, see the white pins? well squeeze the bottom of them if you can and pull, they should pop right out. and to reinstall just push them back in. Simple as that.
<tr>
<div>
Originally Posted by <strong>Jimmy2Shoe</strong>
</div>
<div style="font-style:italic">Alright, sounds like a plan... now I have to go buy small 40 MM fan though! I have some zipties and some string, I'll see if that will help...<br />
<br />
Is it easy taking off the NB heatsink?</div>
</td>
</tr>
</table>
</div>You might be able to screw the fan directly in between the heatsink fins. You won't know until you do a test placement.
Discussion Starter #16
I looked at my options and 40mm fans are pretty hard to come by in Canada, at least reasonably priced ones.... however, I have 2 choices:<br />
<br />
<a href="http://www.ncix.com/products/index.php?sku=18623&vpn=ZM-NBF47&manufacture=ZALMAN%20TECH" target="_blank">http://www.ncix.com/products/index.p...=ZALMAN%20TECH</a><br />
<br />
or <br />
<br />
<a href="http://www.ncix.com/products/index.php?sku=15865&vpn=40MM%20CASE%20FAN&manufacture=ANTEC" target="_blank">http://www.ncix.com/products/index.p...ufacture=ANTEC</a><br />
<br />
bear in mind that I have to pay 10 shipping no matter what I do.
Excel Guru
You can't base something like that on touch. Your body temperature is just below 100 degrees F, which is around 37 degrees C. At this temperature, you will start to definately feel the heat (almost as hot as a typical hot tub). But, as I'm sure you are aware, 37 deg C is quite good for a northbridge temperature. In other words, just because yours is getting hot to the touch doesn't mean the temperature is outrageous and/or worrisome.
<tr>
<div>
Originally Posted by <strong>stargate125645</strong>
</div>
<div style="font-style:italic">You can't base something like that on touch. Your body temperature is just below 100 degrees F, which is around 37 degrees C. At this temperature, you will start to definately feel the heat (almost as hot as a typical hot tub). But, as I'm sure you are aware, 37 deg C is quite good for a northbridge temperature. In other words, just because yours is getting hot to the touch doesn't mean the temperature is outrageous and/or worrisome.</div>
</td>
</tr>
</table>
</div>He said he couldn't hold his finger on it and that could be 60C+
If you can put a good 120 in the front of the case and another in the back that should be fine I had a PW5D and the NB was so hot you couldent hold you finger on it as well but just added a side fan and beefed up the cross venting.
Daves not here man
My s3 gets a little warm to the touch at 420fsb, i just added a 120mm fan in the case and it made a big difference
1 - 20 of 22 Posts
