Northwood overclock?
457 6
so i have a p4 northwood 2.8ghz and i have it overclocked at 3.8. I was wondering if any1 else has a northwood and what there highest overclock was because i had it at 4.0 but it failed prime.
1 - 7 of 7 Posts
thats a nice clock that mate, but i cant help you, i would advise gettin better cooling dependin on you budget i would get a good water cooling system and if you on a budget(like me
) haha i would get a big typhoon as everyone thinks there amazin! soo yeh go for that i am
With some upgraded cooling, weather its an XP-90 or 120 heatsink and fan or watercooling, it would definately help you up your OC. What are your temps when overclocked? I dont know what that cooling is
never heard of it!
The best I have ever made (On Air) is 3.8GHz fully stable at Prime95 (2 Instances 24 hours).
I have made 4.0GHz more than a few times with 3.2 Northwoods but they never Primed stable (2 Instances 24 hours) and usually the second core would fail after so many minutes. Now some don't mind if their system does not pass prime95 stable and are more concerned about having the 4.0GHz, but I was taught early on overclock to stability.
R
1 - 7 of 7 Posts
