Not Name Brand Vs. Name Brand
839 Views 12 Replies 6 Participants Last post by  redhat_ownage
Is there a major difference between not name brand vs. name brand in gaming with the same clock. Like this one on E-bay. The item maybe over.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
1 - 13 of 13 Posts
Originally Posted by qTAP
Yes, one major factor is warranty.
I'm talking in performance not warranty.
If the memory modules have the same specifications there is no difference except:
- Quality of PCB
- Quality of heatspreader
In terms of speed, they would be exactly the same as a set that has the same specifications.
Originally Posted by dixson01974
Sorry. but that is PCB.
If you're going to run them at stock speeds, you won't notice any difference. However, the differences become apparent when trying to overclock with no name RAM. It's hit or miss. Also, you'll find that some of the name brand uses better chips that can run DDR2 1066 with only 1.8v vs the 2.0-2.1 that his requires which probably means 2.1 or higher.
You mean what it is? It means Printed Circuit Board. The memory chips are attached to the PCB.
They will be at stock speed. They are for my two nephews computer. I'm doing upgrades for them.
Is it a custom built computer i.e. does it have an after market motherboard in the machine? The reason I ask is because if it's not, you'll have to check their motherboard's specs to see what voltage it runs RAM. Because the BIOS will be locked, you can't bump up the volts to the 2.0-2.1-2.2 this will require and thus it will only run at whatever speed it has set in it's profile for 1.8v
I'm upgrading the mobo and memory for now. Later i'm upgrading the cpu from phenomI 9500 to phenomII 550BE. Only one cpu will be oc with aftermarket HSF in ASUS M4A79 Deluxe multiplier only.
One more question. Can I mix the memory with OCZ 1066 timing and voltage is the same? I'm thinking YES. Your thoughts please.
you can mix ram all you want, but it will just run all ram at the lowest ram speed in the group.
if the timings match then it will work fine if you set it to 1066 in bios and leave timings on auto
1 - 13 of 13 Posts
