1 - 20 of 41 Posts
I just put together my new setup today x2 3800, evga 7800gt, 1 gig OCZ platinum 3200, and a asus A8N-SLI. For some reason iam only gettin at the most 70fps in css where with my 9800pro i was gettin 120fps? Am i missing somthing? Is their somthing that i have to set in the Nvidia settings? I should be able to play fear with the setting on maximum but it lags like crazy like 2 second pauses? I have the drivers and everything installed.
my first guess is your ram.get 2 gigs .you need better ram for better graphics. I can't even play fear right now
but 2 gigs are on the way
EDIT: CS:Source is ATI's game so therefor ati's will almost always own nvidia cards *but only in css*
check the power supply. if its not supplying enough power to it then it will run slow and unstable (freezing and stuff)
my FAQ explains it all
You don't really need to get 2 gb. He has 1gb Platinum that's a good ram and 1 gb still good for recent games..
just trying to help
like I said it was just a guess.
edit: i was looking at his profile instead of what he wrote
Make sure it's getting engough power, and delete every single bit of ATI drivers...they might be hiding in your registly
just trying to help
LoL no that's okay, i'm not trying to be mean
..Maybe, i may be wrong on what i said.
Discussion Starter #14
only the one i believe, the other is so you can run something else off of it,
make sure when you go into your nvidia options- there should be a little icon in your tray or you can right click on the screen- properties- settings - advanced and then make sure you do all your adjustments like your refresh rate, performance setting (high quality to high performance which ever one you like) all that good stuff
you just need to plug one molex from your psu into that converter but i wouldnt have anything else like lights or fans or dvd burners connected to that line that you have your 7800 connected to.
you only need to plug in one of the 4-pin connectors to the 7800. the second is if you need to use that same rail for another device. you should plug in a "male" 4-pin connector (the one without the 4 metal rods sticking out) from the power supply into the cord for the 7800. that will give it power. other than that...i think that there are some problems with dual-core CPU's and CSS. i have a 3700+ @ 2.6Ghz and a 7800GTX, and my frames are in the upper 100s, often in the 200s, lol, so i think it may have something to do with your CPU as well, especially since the game is heavily CPU limited.
Originally Posted by aero52788
what about the one above the pci-e slot?
only need to hook that up when running SLI. it's so the graphics ports have a dedicated power line from the powersupply
I'm pretty sure that you need to plug in 2 molex plugs in to that adapter for the best performance.
1 - 20 of 41 Posts
