1 - 3 of 3 Posts
Hey guys Im fairly new to overclocking .Any advice would be appreciated .I recently installed a aquagate mini r80 cooling system on my processor and have tried manually to oc my system every time i try to go over 2.20 i get this message.Reboot and select proper boot deviceor insert boot media in selected boot device and press any key .I was told a good place to start is memory i have 1 micron pc3200 1GB DDR installed right now with plans to get 1 more .Any suggestions as to values and settings would be hugely appreciated
Work through this guide: http://www.overclock.net/overclock.p...king-guide.htm
This should help you figure out what is causing the instability and help you get the max out of your system.
your RAM probably can't handle too much of an OC... but try to set your RAM on a dividor and just OC your cpu
1 - 3 of 3 Posts
