Nov 2009 Rebuild and Upgrade - How did I do?
296 Views 2 Replies 3 Participants Last post by  detroitpc313
Otay, so I recently did a rebuild of my compy to do a little wire managing and to redo my loop because I got NB and SB block and new tubes, etc.
Parts:
Dtek Fuzion
MCR320 Rad
MCP655 Pump
Swiftech Micro Res v2
EK NB 780i Block
EK SB 790i block
Thermochill 1/2" ID uv green tubes
Petra PT Nuke + distilled water
1 - 3 of 3 Posts
Parts:
Dtek Fuzion
MCR320 Rad
MCP655 Pump
EK NB 780i Block
EK SB 790i block
seems nice but get a 90 degrees fitting look like tubing is kinking...
from cpu to south or northbridge
yea i would put some fittings from your rad to your cpu block you are stopping all your water pressure there you well get better temps for sure besides that it looks gr8
1 - 3 of 3 Posts
