I have been waiting so long and it's finally here. Here are some pic's but benchies will have to wait till sometime tomorrow.
I am afraid
of the weight
and will do a bit of research on mounting. I also have 3 kinds of paste Shin Etsu, OCZ Freeze and AS5. Haven't tried the Shin Etsu before so most likely will give that a run. Any suggestions on mounting or paste please they are all welcome.
Now on to the pic's-
More Pic's of her installed on motherboard.
UPDATE November 23, 2008
All right so today is the day to test the Copper TURE (unlapped) some more
Due to time constraints I will only be able to apply 2 I chose “Trusty Ol’AS5†and my favorite “OCZ Freezeâ€. I am very fond to the OCZ as it has a very easy application and on other set-ups; has delivered.
Of course I used my sig rig and the Copper TRUE had push pull using 2xYate loons 120mm. Now on to the tests…
AS5
Ambient temps: 20.83c (-7c outside)
Idle
Q6600 @ 3600 w/ 1.48 vcore (bios) 1.472 (windows report) 27c
Full Load
Q6600 @ 3600 w/ 1.48 vcore (bios) 1.488 (windows report) 57c
OCZ Freeze
Ambient temps: 20.43 (-7 outside) Getting warmer as the afternoon comes upon us
Idle
Full Load
Q6600 @ 3600 w/ 1.48 vcore (bios) 1.488 (windows report) 54c
Not too bad but very time consuming. There is definitely a difference between the two thermal pastes. As you can see OCZ seems to have performed better. Well that's it for now but will post more between today & tomorrow.
Update December 2, 2008
Had some time to kill today now that I have taken a week off of work
I finally got around to lapping her (sorry no pics camera was destroyed on Thanksgiving) I was pleasantly surprised at the results,
Full Load
Q6600 @ 3600 w/ 1.48 vcore (bios) 1.472 (windows report) 51c
This was far better that I expected. It's about 5c-6c warmer in the house than when I ran my previous tests. I am curious
to see what the results would be if my Q6600 was lapped. Anyways, thanks to all who have helped me out...
Will update with my last 2 tests of thermal paste and lapped Q6600.
Update of the lapped copper true. I was applying the washer mod + applying the I7 Diamond thermal paste figured I would take a pic of the final product. My camera is not so good (old camera, very old) anyways will be posting the results of the diamond thermal paste after some curing time.
UPDATE December 12, 2007 IC7 Diamond results
Well, I had high hopes for the Diamond IC7 thermal paste. Didn't even come close to expectations. There are many reason why it's not worth the money but I will only list the top disappointments that I have had with it so far.
1. To expensive
2. PITA to apply
3. How long it takes to cure
4. Most of all; poor results in temps. Yes I had to re-seat many times only to find same poor results everytime.
I spent about a week doing all of the above. I researched many applications and found the best results was the 5mm dot in the middle of the CPU. With my TRUE lapped I noticed that it spread nice and even accross the Q6600 so that wasn't an issue. Didn't look to be a lot of air bubbles. Anyways I will not go on on to the results them selves.
As you can see much higher temps than the other. Never again will I but this stuff.
Tests Left:
1.IC Diamond thermal paste
2.Shin Etsu thermal Paste
Mods Left:
1.Washer mood
2.Lapping
I am afraid
AS5
Idle
Full Load
OCZ Freeze
Idle
Full Load
Full Load
1. To expensive
2. PITA to apply
Tests Left:
Mods Left:
1.Washer mood
2.Lapping
