Hello
Planning to go Mini ITX again and interested in this case, the normal version not the TG variant
My concern is the GPU I am using for this build (1080TI FTW3 Hybrid) and where to position the Rad and its 120mm fan
the GPU would be mounted horizontally.
My image is as the PSU shroud is perforated, it would pass through heat into the case then the RAD and vice versa get heat from the GPU RAD
I have made a sketch with Options to mount the RAD on the side bracket but as I haven't seen any build with GPU AIO to confirm what would be the best thermals
thanks so much.
