1 - 12 of 12 Posts
Ok guys I just got this new intel 650 cpu. I swapped my 530 for the 650 and the cmos got reset like normal. I tried to go into windows (everything stock) and got this message:
NTLDR is missing
Press Ctrl+Alt+Del to restart
Nothing I could do would let me go past this error. Repairing windows didnt fix it. I reformatted, installed all my drivers and everything, and then went to overclock. I went to 240 FSB and boom it happened again. I raised some voltages and backed everything back to stock and its still there. What is the problem here? I ran this board with raid everyday at 254 FSB so I dont see a problem with anything...
Try reading This or this that will go through step by step solutions to fix your problem.. If you ask me, i think it is your bios..try flashing to the latest one and see if that works.
NTLDR is missing
Just to start with the easiest solutions, you don't have a nonboot floppy in your drive,do you? That message indicates that it's looking for the boot sector, but can't see it or it's corrupted. I'm sure you've checked, but can't hurt to mention it...did you check to make sure your BIOS boot options are set correctly?
Discussion Starter #5
Boot is set to CD then HDD and theres no CD in the drive. There is no floppy drive (I removed it) and I tried HDD then CD, same issue.
It's not seeing the boot sector on your hard drive, so it's got to be a loose or bad cable. Any chance you have an extra laying around to swap it with? It's worth a try because I doubt the actual boot sector is corrupted. It's just not able to read it for some reason and a bad cable seems as logical as anything else.
Discussion Starter #7
Nope because the problem is fixed after I reformat and run at stock.
Have you run a diag. on the HDs to be sure they aren acting up?
Discussion Starter #9
Downloading that now.
You should also turn on S.M.A.R.T. in your BIOS.
Discussion Starter #11
Fixed!!!
Not sure why but I had a usb drive connected and it took that over the raid when trying to boot. I've never had this problem before either! Thank god its fixed it was driving me crazy lol.
Pfft, you didn't listen! J/k
1 - 12 of 12 Posts
