1 - 9 of 9 Posts
i try to bypass the security checks to install a modded Pascal VBIOS ( http://forum.notebookreview.com/threads/mobile-pascal-tdp-tweaker-update-and-feedback-thread.806161/ ) and found an interesting node.
i think the security check starts somewhere after the "EEPROM ID"..... line.
which subroutine starts the flashing after the security check?
im not a programmer and its my first attempt so please use a more beginner friendly language here.
i had the idea after i came across this thread: http://resources.infosecinstitute.com/applied-cracking-byte-patching-ida-pro/
Discussion Starter #3 (Edited)
sub_1401D2CB0 writes the line EEPROM ID(...) : ..... , page
only sub_140111D60 and sub_1401137D0 containig all the success lines, it looks like sub_140111D60 is part of the searched flashing routine.
Discussion Starter #4 (Edited)
when i try to save the file with pe_write.idc it doesnt save the changes i made in the database i think because the script is outdated.
there are more sections than pe_write.idc writes.
EDIT:
use the "Apply patches to input file..." option under edit>Patch program.
Facepalm
Wait, this allows flashing a pascal modified Bios?
Discussion Starter #6 (Edited)
yes this is what i try with IDA Pro but its very hard to find the point(s) in the code to bypass the certification check.
learning assembly language from the sketch takes too much time i dont have so i think i wont find it by myself.
btw. this looks interesting and its part of the flashing after the EEPROM ID stuff: sub_1401B8E00
I've done some experimentation myself, I jmp over the failures and continue execution, but it does not successfully write anything to the card, the write function is returning a error indicating a incomplete verification state....
I think previously with Maxwell it was a internal check only within NVFlash, I suspect with the new license setup the the verification is likely performed on the card itself after the firmware payload has been written to a temporary buffer on the card. so I'm starting to think any amount of messing around with NVFlash will not result in a successful flash.
You can see patched and unpatched behavior in the screenshots.
Interesting topic.....Does it make any callbacks to the internet or did you just stop after you starting seeing the internal and external verifications?
1 - 9 of 9 Posts
