1 - 4 of 4 Posts
sɪɴɢɪɴɢ ɢᴏᴅᴅᴇss
when ever I try to do "nvflash --eraseeeprom" it just prints out the help guide and then nothing...
I'm fairly certain this is preventing me from unlocking my gtx 465.
I have tried multiple versions of nvflash, and the Windows version just says "this program cannot be used in DOS".
I am using a flash drive to boot up from into DOS.
Not new to Overclock.net
I think the best method is to say it as you type it. So, say this while you're typing:
"nvflash space hyphen hyphen erase, e, e, p rom". Otherwise you might end up only typing "erase, e, p rom".
Reactions: kennyparker1337
sɪɴɢɪɴɢ ɢᴏᴅᴅᴇss
Well thank you.
It worked, and I don't know why.
Maybe I kept leaving out 1 hyphen or something.
It worked and now I have a GTX 470.
FYI: I set the fan to 100% and ....
I thought a mini-jet was taking off from a runway right next to me.
Originally Posted by kennyparker1337;12059858
Well thank you.
Nice!
I think the usual reason why it doesn't work is due to typing "eraseeprom" instead of "eraseeeprom".
1 - 4 of 4 Posts
