[Nvidia] 195.62 WHQL for laptop
1416 Views 15 Replies 7 Participants Last post by  Juggalo23451
New in this release:
* Adds GPU-acceleration for smoother online HD videos with the new Adobe Flash 10.1 beta. Learn more here.
* Adds support for DirectCompute with Windows 7.
* Adds support for OpenGL 3.2.
* Adds support for OpenCL 1.0 (Open Computing Language).
* Adds support for CUDA Toolkit 3.0 features and performance enhancements. See CUDA Zone for more details.
* Adds SLI and multi-GPU support for many top new gaming titles including Borderlands, Call of Duty: Modern Warfare 2, FIFA Soccer 10, and more.
* Includes numerous bug fixes including improved performance for Need for Speed: Shift. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
* Installs NVIDIA PhysX System Software v9.09.0814.
Existing support:
* Supports NVIDIA PhysX hardware acceleration on GPUs with a minimum of 256MB dedicated graphics memory and 32 processing cores.
* Supports GeForce Plus Power Pack #3. Download these FREE PhysX and CUDA applications now!
* Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10 and OpenGL.
* Supports NVIDIA SLI Multi-monitor support, giving you the ability to use two monitors with your GeForce graphics cards in SLI mode. Learn more here.
Vist64/win764
Win732/Vista32
Xp32
Xp64
1 - 16 of 16 Posts
Very nice, thanks for the heads up.
Sweet
I would +rep you if I could.
Installing on my XPS M1730 laptop now, will see if it makes any difference to my 8700M GT.
I don't know but for me they suck, some games stutter even if the FPS are playable and the FPS are very unstable, jumping all around, reverting back to the good 5 months old WHQL lol. Maybe something is conflicting on my PC so the day I reinstall Windows, I'll check them out.
I think it is just you. I do not get any stutter when playing games on my laptop
Probably, I need to reinstall a few stuff I think, I have an idea on what's causing this. Just a quick question, what is the default digital vibrance on these drivers? 0% or 50%?
Wohoo! Finally I can update my graphic drivers for my VAIO... NOT!
Originally Posted by Juggalo23451 View Post
Glad to hear that
Could you please tell me if in your control panel, under "adjust desktop color settings" if digital vibrance is set to 0% or 50% by default?
Thanks.
Originally Posted by emmanuel View Post
could you please tell me if in your control panel, under "adjust desktop color settings" if digital vibrance is set to 0% or 50% by default?
Thanks.
50
Thanks!
I tried the beta drivers out before this and it made all my high-def .mkv videos lag so reverting back to the 186 drivers fixed that. Hopefully these wont cause the same problems.
Then again - I suppose it's called beta for a reason.
Cheers for the heads up.
hmmmmmmmm, i might have to try this
1 - 16 of 16 Posts
