1 - 3 of 3 Posts
Hi,
I want to put a passively cooled heatsink on my PNY 1gb GTS 450.
I seen somewhere that is uses the same heatsink hole layout as the 250.
Would a Accelero S1 Rev. 2 i have had a look on the artic cooling website and it says it is compatiable with the 450.
will i need any special tools to make it fit and what would the temps be like would i need to fit the fan?
thanks
alex
notNOTmbudden
No special tools will be needed.
I had one on my 8800GT. Make sure you do know that it will take up a good amount of slots. I think it was like 2 1/2 with just the Accelero & then like 3 - 3 1/2 with a fan on it.
It does pretty good passively without a fan though.
What would the Thermalright T-Rad2 be like there are about 40 pound on ebay
thanks
1 - 3 of 3 Posts
