1 - 20 of 21 Posts
DailyTech spends more quality time with NVIDIA's upcoming GeForce 8800GTX
NVIDIA is set to launch its upcoming G80 GeForce 8800GTX and 8800GTS graphics cards next week, however, DailyTech has managed to obtain a GeForce 8800GTX board to run a couple quick benchmarks on. The GeForce 8800GTX used for testing is equipped with 768MB of GDDR3 video memory on a 384-bit memory bus as previously reported. Core and memory clocks are set at 575 MHz and 900 MHz respectively. Other GeForce 8800 series features include 128-bit HDR with 16x anti-aliasing and NVIDIA's Quantum Physics Engine.
Previous NVIDIA graphics cards in single card configurations were limited to lower levels of anti-aliasing. With the GeForce 8800 series, users can experience 16x anti-aliasing with only a single card. DailyTech has verified the option is available in the NVIDIA control panel.
The physical card itself is quite large and approximately an inch and a half longer than an AMD ATI Radeon X1950 XTX based card. It requires two PCI Express power connectors and occupies two expansion slots. An interesting tidbit of the GeForce 8800GTX are the two SLI bridge connectors towards the edge of the card. This is a first for a GeForce product as SLI compatible graphics cards typically have one SLI bridge connector.
Having two SLI bridge connectors onboard may possibly allow users to equip systems with three G80 GeForce 8800 series graphics cards. With two SLI bridge connectors, three cards can be connected without any troubles. NVIDIA is expected to announce its nForce 680i SLI and 650i SLI chipsets with the GeForce 8800 series. NVIDIA nForce 680i SLI and 650i SLI based motherboards are expected to have three PCI Express x16 slots.
Moving onto the performance DailyTech has selected Half Life 2: Lost Coast, Quake 4, Prey and 3DMark06 for benchmarking. These games and applications were selected as other games use the same game engine. In addition to performance tests, DailyTech was also able to measure power consumption.
The test system configuration is as follows:
* Intel Core 2 Extreme QX6700
* NVIDIA nForce 650i SLI based motherboard
* 2x1GB PC2-6400
* NVIDIA GeForce 8800GTX
* PowerColor ATI Radeon X1950 XTX
* Western Digital Raptor 150
Futuremark 3DMark06
Radeon X1950 XTX GeForce 8800GTX
Score
7026 11200
Kicking off the benchmarking festivities is 3DMark06. NVIDIA's GeForce 8800GTX scores 59% higher than ATI's current flagship. This isn't too surprising as the GeForce 8800GTX has plenty of power.
Half Life 2 4xAA/16xAF 1600x1200
FPS
60.74 116.93
Quake 4 4xAA 1600x1200
FPS
34.23 65.93
Prey 4xAA/16xAF 1600x1200
FPS
55.53 88.87
Half Life 2: Lost Coast loves the GeForce 8800GTX. Here the GeForce 8800GTX is able to show significant performance gains over AMD's ATI Radeon X1950 XTX-approximately 92%.
Quake 4 shows similar gains as Half Life 2: Lost Coast too, an approximate 92% improvement.
Prey is based on the same game engine as Quake 4. However, Prey shows smaller performance differences between the GeForce 8800GTX and ATI Radeon X1950 XTX, albeit its still 60%.
Power Consumption
Watts
Idle
184 229
Load
308 321
Power consumption was measured using a Kill-A-Watt power meter that measures a power supply's power draw directly from the wall outlet. The power supply used in the test system is a Thermaltake Toughpower that carries an efficiency rating up to 85%.
DailyTech previously reported NVIDIA recommends a 450-watt power supply for a single GeForce 8800GTX graphics card. This isn't too farfetched of a recommendation. Power consumption of NVIDIA's GeForce 8800GTX isn't as bad as expected. When compared to AMD's current flagship ATI Radeon X1950 XTX, the GeForce 8800GTX only consumes 24% more power at idle. The power consumption differences under load decreases to around 4%. Considering the performance differences, the GeForce 8800GTX is no worse than AMD's ATI Radeon X1950 XTX in terms of performance-per-watt.
Expect NVIDIA's GeForce 8800GTX and 8800GTS graphics cards to be available next week. As NVIDIA has had plenty of time to ramp up production and ship out cards, this will be a hard launch with immediate availability.
http://www.dailytech.com/article.aspx?newsid=4812
Basically 8800GTX pwns X1950XTX for the time being.
Thing is everyone said, "Oh nooo, look how much power it uses, we need 1KW PSU's for SLI", and I always said, "we have to wait and see, and I doubt it will need 750W for SLI, let alone 1KW". And look what it says:
So I was rite, just 4% more power consumed under full load than the X1950XTX
Here is some numbers:
GeForce 8800GTX
- Idle = 229W
- Load = 321W
The rig was using a QX6700, 2x1GB DDR2-800, 150GB Raptor and a 8800GTX and you could run it all on a measly 400W PSU probably. There isnt a huge difference between Idle and Load anyway so full load in SLI could probably be run on a 500W PSU (220W for cards, 230W for rest of system).
THREE cards?
Yea bring on the dual 1000W PSUs...
Discussion Starter #6
Originally Posted by Murlocke View Post
THREE cards?
x.x
Discussion Starter #11
Originally Posted by HrnyGoat View Post
Now we just have to worry about price.
* XFX 8800GTS 640MB 500MHz $509
* XFX 8800GTX 768MB 570MHz $679
* eVGA N821 8800GTS 640MB $499
* eVGA N831 8800GTX 768MB $669
* Asus EN8800GTS/HTDP 640MB $459
* Asus EN8800GTX/HTDP 768MB $609
* MSI NX8800GTS 640MB $519
* MSI NX8800GTX 768MB $689
* BFG 8800GTS 640MB $499
* BFG 8800GTX 768MB GDDR3 $679
These prices are based on my cost plus your typical "mom and pop" VAR markup. Some retail store (Best Buy, CompUSA) prices may be higher. With back end rebates, co-op, etc., some e-tail (Newegg, Tiger, etc.) will likely be lower.
Numbers are from jonnyguru
Discussion Starter #13
Yes, but if theres a shortage, the price will go way up. I remember what happened the last time nVidia tried to use 1.8GHz GDDR3 on a card...
According to the dailytech article availability shouldn't be an issue
Because there wont be very many people willing to shell out that much money for a single video card.
Old school
Hmm, the MSI 8800GTX costs €574 here.That's $689.
I love how it's really weak in 3Dmark06, but in actual games it's getting around +150% performance with AA slid to the max, compared to all our GeForce cards.
While impressive, isnt quite worth the upgrade from my GTX, yet.
On a side note, I might go ahead and buy me that 750W Silencer, since it seems it might be able to run these in SLi.
1 - 20 of 21 Posts
