1 - 11 of 11 Posts
Overclocked
GTX 460 is stronger it is comparable to HD6850.
Also what is the brand of your psu?
A high quality & branded 520 watt PSU can handle any of those cards without problems.
GTX 460 hands down.
& what's the brand of the PSU you own ? If it's a Thermaltake, Cooler Master, Corsair etc then you're good to go
Overclocked
ACE? I didn't know if there is some good brand named like that.
Just buy a new power supply to be in the safe side.
Overclocked
OCZ StealthXtreme is a high quailty PSU it can handle both without problems.
GTX 460 for sure
the ocz 600w power-supply will be plenty
1 - 11 of 11 Posts
