1 - 15 of 15 Posts
You could. Dont even have to OC it. But... you'll want to anyway.
Im positive. It will run so long as you have a fast enough proccessor. Even if you barely make the minimum specs, it will run.
That's not really crappy. You shouldn't have any problems playing HL2. It just won't have all the bells and whistles enabled that make it look pretty. You'll need a high end card for that.
Any Intel that has HT isnt crappy. Though, I dont like Intel personally.
Not really. Intel has let me down where AMD has not. So I stick with what works for me.
You won't have any problem running Half Life 2 because it is scalable. Pretty much if you have a 1.5Ghz CPU and a DirectX 7 graphics card you can play. But let me tell you that you will be missing a lot of the details that make Half Life 2 the revolutionary game that it is. That is exactly why I haven't bought it yet. I am getting a new graphics card for christmas and I am waiting 'till then to start HL2. I don't want to miss a thing!:santasmil
1 - 15 of 15 Posts
