1 - 12 of 12 Posts
Vandelay Industries
Discussion Starter · #2 · (Edited)
Thinking about cleaning that hob mantle and backsplash makes me cringe.
Oooh and is that a crocodile coat? Ahh he changed coats 3/4 way though!
Vandelay Industries
That's the premise, but may be difficult for Nvidia if their acquisition gets blocked. If it does I'm sure (I'm not sure) it'll be a "joint" venture.
Zen
None of the stuff they showed today requires ARM acquisition to go through.
Are they using some kind of integrated power stages with FETs on top of the inductors? What the heck am I looking at?
2486368
Your next computer. Nvidia GPUs are basically self contained supercomputers and it no longer makes sense for them to rely on the CPU for instructions. I hope they release a GPU with 48GB shared VRAM and a SoC CPU that doesn’t even require a motherboard.
Yeah that was the closest thing I could find too.
Yeah, that's what I'm waiting for, a single chip with GPU and CPU that actually kicks ass. Having them on the same board works too I guess. What I think would be really cool is an FPGA with tons of cores that can be configured on the fly for graphics or regular compute tasks. Imagine if a chip could balance itself when gaming, designating the exact ratio for compute and 3D that is needed to put 100% of the chip to use. No CPU bottlenecking the GPU or GPU bottlenecking the CPU. 🤔
Yes
Yes, no more PCIE bottlenecking either. The CPU will be on the same PCB as the GPU with optical traces inbetween. In 10 years the whole concept of buying a “card” and sticks of memory and slotting them into a motherboard with RGB lights will seem as ridiculous as a Honda Civic with a body kit and neon lights. You won’t have to build and tune your computer anymore, courtesy of Nvidia.
Vandelay Industries
Discussion Starter · #11 ·
I'm not with y'all on that enthusiasm. What I see is a need to replace an entire system now instead of a single component to remain relevant. I like the modularity of today's systems.
You should get into retro computing. Even the cards have card slots! The YT channel Lazy Game Reviews is a great place to start.
2486436
1 - 12 of 12 Posts
