1 - 7 of 7 Posts
Yes, portrait mode is supported with monitors with resolutions up to 2560x1600. You should be able to reorient your monitors in the nVidia control panel.
I know that portrait orientation is supported... But I need to know if I can make PLP setup work (portrait -landscape-portrait). Basically I would need to find two smaller monitors and put them up in portrait mode around my 24" landscape main monitor...
PS: I know that this is doable with ATI Eyefiniti setup... but game must be windowed.
Like this:
I believe all of the monitors need to be set at the same resolution. You could use Softth to accomplish the task at hand.
Fortnite Fanatic
I've seen it done. But it was hacked. Looked very nice.
1 - 7 of 7 Posts
