I have a question, Why when I'm running the memory at 2400 MHz (2600 MHz KIT) in the Event Viewer, I have this error.
"The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
Include the following information with the event
/Device/Video7
00b2(1de8) 00000000 00000000"
I have this error very often, in an hour I can have 2, or I can have 6.
But I run all games without problems, I dont have a crash, no BSOD, everything seems to work fine, until I'm running Prime95 right now, and I have 7 hours without problems, so I let it run longer.
314.22 WHQL
2x GTX 680 SLI
i7-4770k
Gigabyte G1.Sniper 5
16 GB RAM GSkill Trindet X 2600 MHz, but im running 2400 MHz
The RAM is stable, I have 15 hours with Memtest86 without problems, and now I am running Prime95, for 7 hours, and I will not stop.
It is not really a problem, I dont have a crash, but I would like to know why I have this error in the event viewer.
What can I do ?
/Device/Video7
314.22 WHQL
2x GTX 680 SLI
i7-4770k
What can I do ?
