NZXT FS-200RB-RLED 200mm Silent Fan with ON/OFF Switch
Description:
Add some color and quiet cooling to your desktop PC with the NZXT FS-200RB-RLED 200mm SLIENT Red LED Fan. Spinning at a low 20.16 dBA at around 700rpm, the fan can be used to pull cool air into your system or push hot air out. Either way, the result is a lower overall operating temperature with little added noise. With the red LED on/off switch, it glows brilliantly when it is on, adding a splash of red color to your case’s interior and is a perfect addition if you have a clear side panel. Type: Case Fan Bearing Type: Rifle Bearing RPM: 700 rpm +/- 200 Air Flow: 89.5 CFM Noise Level: 20.16 dBA Color: Transparent Compatibility: Case Dimensions: 200 x 200 x 30 mm
Details:
Description:
Details:
Detail | Value |
Manufacturer | NZXT |
Condition | New |
Model Number | FS-200RB-RLED |
Classification | Case Fans |
