so im dead set on getting a phantom. problem is i have an extended MOBO (SIG) so i need to get a case that supports that. plus if im paying this much for a case i might as well make sure it will hold any upgrade i will put in it in the comming years. with that being said how much better is the 820 than the crafted? i really like the fact that i can change the color of the LED and the window on the side of the 820. its just so damn big tho. is the 820 really worth the extra $100 it cost or should i just get the crafted? links of the 2 in question :
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146096
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146079
