1 - 4 of 4 Posts
Hey,<br><br>
A while ago I bought the NZXT Trinity. It was really advertised as the TRINITY-version with picture and all. So when I got it I was really dissappointed to discover it was the NZXT Trinity LE w/o see-through side-panel.<br><br>
I don't know why I didn't send it back, but that's history now. I want a see-through side-panel on my case and am searching for one. I just send NZXT an e-mail about this and was wondering if they sell the see-through side-panels. But for now, I am considering about buying a side-panel that has the same measurements as my Case' side-panel. Which are By The Way: 200X440X430 cm<br><br>
So does anyone know a see-through side-panel designed for another case with those measurements? Or is it a (<img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">) no-go?<br><br>
Regards<br>
~AMD-rules.
Discussion Starter #2
Anybody?
9 Cans of Ravioli
Mod your own.<br><br>
Cut hole. Put pelxi in it. Or, if you are "lazy" (or don't want the hassle <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">) just stick a sheet behind the window. <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
You could just get a piece of Lexan and mod it your self. With your own custom take on it. Also you can buy kits.<br><br>
Here is a couple kits that you can <a href="http://www.frozencpu.com/cat/l2/g1/c11/list/p1/Cases-Window_Kits.html" target="_blank">buy</a>. But I am not sure where you can get them from in the netherlands, or who ships there. You best bet would be to just mod it your self if you can't get one direct from NZXT.
1 - 4 of 4 Posts
