Ok so i just got my mobile 2400+. It works fine with my system. My mobo doesnt manually multiply over 12.5 ( the last multi is marked >=12.5 ) so i put my multi on auto and my comp did the rest. So now its running at 13.5x133, or 1800mhz and its only at 30 degrees C. Which is good since i used to have a 256cache 1.2 tbird that ran at 58 C.
One question is, Is there a way to get a higher multiplier than 13.5? My mobo is capable of recognizing a 2600+ ( just got new bios ). Can i like, trick my mobo?
2nd. I have 2 sticks of ram in my comp, both are spectek ( think its cheapy ram). One is pc2100 and the other pc2700. In bios i can up my fsb to a max of 150, i think. But i want to know if my ram will keep up? Dunno if it matters but the CPU-Z thing says my timing for the 2100 is 2.5-3-3-6 and the other 2.5-3-3-7.
Thanks for any help. Damn this mobile + a volcano is sweet. Best 100 bucks ive spent in a while.
