The problem I'm having is whenever I enable Vsync in game, which I have to do because I cant stand screen tearing, the framerate halves to whatever refresh rate I'm running, if I set the monitor to 110hz, the game will be locked at 55hz unless I disable vsync, if I set the monitor to 100 hz, it locks it at 50, 116 hz locks it at 58, I know vsync usually halves the framerate if it cant keep up but this is different, it will never go above those lower framerates, even with every option on low and looking at the ground, unless i disable vsync, i can confirm the framerate by using radeonpro, even using dynamic vsync enabled in radeonpro and vsync disabled in game, it will never go above the half of whatever HZ the monitor is set to, i even formatted my win8 system and reinstalled windows 7 helping that would fix the problem, but no dice. I've tried triple buffering, limiting hte framerate to 1 or 2 fps below the refresh rate and then enableing vsync, it will still half my framerate to whatever its set to, this wouldn't be a problem if my catleap could reach 240hz ;p cuz then I could just deal with the 120fps
