1 - 5 of 5 Posts
I currently have a XFX 7600GS and I was thinking at some stage I mite over clock it. I am wondering what kind of performance gain I mite be able to expect from it?<br />
<br />
Currently the Temperature of it is 35 C idle and 40 C playing Oblivion.
How many fans do you have?<br />
I have 1 ponting directly at the gpu and my idle is 57º....
Got mine to 465 core 360 mem (1080Mhz) vs 400/266 (800Mhz mem) and it runs quite hot (83C on load) and that with 2 fans directly over it. You'll get about 10-20 extra fps.
Discussion Starter #4
I have one fan on the GPU heatsink. my idle is 35 C. Stock not overclocked.
I guess because the GPU (mine) only have the fan over it (no heatsink), it's that hot. If you have a heatsink then it probably lower. You can allow a little overclock.
1 - 5 of 5 Posts
