1 - 20 of 31 Posts
Now continuing my 1st time overclocking attempt my AMD64 3800+ (single core) was at 2.71Ghz which was my limit to a stable overclock. Tried 2.75Ghz and it was running my Corsair Value ram a touch higher than it should and caused lock ups as soon as windows loaded up. Now after reading further in the art of overclocking i thought yes my ram will limit my OC, but is it this so early on into my adventure?<br />
<br />
I thought my CPU voltage could be to blame, so i jumped into the Bios and put the CPU voltage up one notch (i'm not an idiot i was very cautious about this). But i made sure i could keep my HTT at a reasonable level of 980 and keep my ram from going beyond it's capabilities. <br />
<br />
Everything is as it was, ram at 333Mhz rather than stock 400Mhz, except i changed the multiplier on the CPU to 11.5 and CPU frequency down a bit to<br />
245Mhz and HT to X4 obviously. And oddly enough it booted into windows without a lockup or BSOD. Now remember i put the voltage up one notch!<br />
<br />
I am now running my AMD64 3800+ @2.82Ghz, although streess testing must be done before i am happy...brb
so your voltage is what around the 1.45 /1.5 vcore range ?<br />
<br />
thats nothing <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
around the 1.6/1.65 vcore is the max for air cooling so youv'e got ages to go.<br />
<br />
nice overclock aswell <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
I'm having issues with anything set at X12 cpu multiplier for some reason, get a blank blue screen currently running the CPU at 1.512 Volts. But i'm afraid to go higher even though my temps are fine....what to do?
what temps do you have at the moment ?<br><br>
idle and load<br><br><br>
You will be fine to go higher with the vcore aslong as your load temps ( as in 100% cpu usage ) dont go higher than 55C<br><br>
what speed is your ram running at now ?
Remember that the memory controller is built into AMD 64's so thats probably an explaination of why your ram works at the same speed it did not before.
Discussion Starter #6
At 2.8Ghz idle 36Celcius. Before at 2.75Ghz i used to get BSOD's, so i increased the volts on a whim one notch and it works upto 2.8Ghz. But as soon as i leave the CPU speed the same and DDR the same (set to 333Mhz) and put the CPU multiplier on X12 i get a blank blue screen. All i ever seem to get is lock ups to be honest, if i manage to get to windows it may lock up there or during a stress test like 3DMark05. But at the moment it works fine @ 2.8 during stress tests and is completely stable.
1/2 CPU multiplyer do not effect the RAM, only the CPU. There is a FAQ on that.<br>
Some bumps on the RAM, chip set and Memory controler voltage may help your overall OCing. Keep working it, you have a very good OC going so far <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #8
I'm totally lost! I can't get 2.8Ghz to work without locking up on 3DMark05. I am depressed, what would be the cause of a PC freezing without errors? A lot of guides saying voltage, but no amount of raising the CPU voltage changes a thing. Odd thing is anything in the 2.9Ghz range fails to get into windows, i get a "blank" blue screen appear and freezes.<br />
<br />
All things are set within their boundries so i'm totally gazumped!
so its posting at 2.8?
Retired
You could try running your memory at a divider, or just upping your memory voltage. I think corsair ram is good up too 2.8? Dont quote me on that, but thats what my xms is rated up to. Remember though, xms has a heat spreader. Also, lowering your HTT might help, I keep mine around 600, as it doesnt really affect performance that much, and can keep your nb much cooler and under less stress.
Discussion Starter #11
It's posted 2.85Ghz, but usually gives me a blank blue screen and locks up.
Retired
<tr>
<div>
Originally Posted by <strong>Mhill2029</strong>
</div>
<div style="font-style:italic">It's posted 2.85Ghz, but usually gives me a blank blue screen and locks up.</div>
</td>
</tr>
</table>
</div>Have you tried running your ram at a divider in order to rule out the CPU as the cause?
Discussion Starter #13
I running DDR400 at 333Mhz. Tried going lower but makes no difference, although like i said before the system was unstable at 2.75Ghz. I now have managed to boot up into windows at 2.8Ghz by raising the CPU voltage to 1.5volts. But it freezes in 3DMark, what would cause this?
Discussion Starter #14
It seems anything around 2.75Ghz or over is unstable for me, i have settled for 2.7Ghz which is perfectly stable. I am at a loss with making 3Ghz, but with Corsair Value ram, 2.7Ghz is quite a reasonable overclock me thinks.
Just remember that no two componants are the same...just because someone else with an identical rig managed to oc to a certain point doesn't meant you will be able to. That said, I don't see why you aren't able to hit 2.8. (Especially since my 3400 was at 2.6, and was only limited by my stupid psu.)
Overclock Failed...
<div>Originally Posted by <strong>Mhill2029</strong></div>
<div style="font-style:italic;">At 2.8Ghz idle 36Celcius. Before at 2.75Ghz i used to get BSOD's, so i increased the volts on a whim one notch and it works upto 2.8Ghz. But as soon as i leave the CPU speed the same and DDR the same (set to 333Mhz) and put the CPU multiplier on X12 i get a blank blue screen. All i ever seem to get is lock ups to be honest, if i manage to get to windows it may lock up there or during a stress test like 3DMark05. But at the moment it works fine @ 2.8 during stress tests and is completely stable.</div>
</td>
</tr></table></div>
You're using the "shotgun" approach to OCing. Change one thing at a time. That way when something goes unstable you will know what is limiting your OC's.
Discussion Starter #17
Oh btw, on occasions my USB will stop functioning at a certain clock rate, plus do you have to change the PCI Frequency to 33Mhz rather than the default Auto? Plus would a Bios update be worth while?<br><br>
I'm using a Jeantech Artic 600Watt PSU, which is a kick ass premium PSU.
Overclock Failed...
<tr>
<div>
</div>
<div style="font-style:italic">Oh btw, on occasions my USB will stop functioning at a certain clock rate, plus do you have to change the PCI Frequency to 33Mhz rather than the default Auto? Plus would a Bios update be worth while?<br />
<br />
I'm using a Jeantech Artic 600Watt PSU, which is a kick ass premium PSU.</div>
</td>
</tr>
</table>
</div>USB: Disable "Legacy Support". NB>SB bus speed will affect USB stability.<br />
<br />
Locking the PCI frequency can give you more stability. Do you have any PCI devides installed though?<br />
<br />
Not really a "kick ass premium" PSU:<br />
<a href="http://www.tomshardware.com/2005/07/11/stress_test/page20.html" target="_blank">http://www.tomshardware.com/2005/07/...st/page20.html</a>
remeber if your going over 250mhz on your fsb you need to set your HT Freq to 3x.Having it set higher with a fsb over 250 will cause instability.
You MUST lock the PCI Frequency. If that frequency goes over 37MHz (Where most boards crap out), you can loose data and such from your harddrive.<br />
I've never heard about JeanTech, so that's <i>possibly</i> your problem.<br />
<tr>
<div>
Originally Posted by <strong>burnstudios</strong>
</div>
<div style="font-style:italic">remeber if your going over 250mhz on your fsb you need to set your HT Freq to 3x.Having it set higher with a fsb over 250 will cause instability.</div>
</td>
</tr>
</table>
</div>That is not always correct, most boards can take 1050MHz on the HTT without problems. A few can go up to 1100, and almost none can go higher.
1 - 20 of 31 Posts
