1 - 6 of 6 Posts
Before u read read my specification for my system plz
i m trying to push to 3.6 (225 fsb) this freaking error keep showing up
Beginning dump of physical memory.
Physical memory dump complete.............contact system adminstrator, etc.
anyone knows what that means?
any recommendation
thnx!!
any recommendation
thnx!!
I have only seen that once before and it was when my old memory sticks were dying... I don;t think that's your case but if they are set wrong the system may think they are.
thats the BSOD, and usally caused by a too large OC. it most likely is your memory, depends on what u have set at. have u changed any voltages yet?
i set it at auto
NO..lol u dont want auto, its the default voltage. u want to manually adjust it, and ull get way better results. read the intel OC guide
1 - 6 of 6 Posts
