Hi guys, sorry if this is a bit of a noob question but.....
I'm looking for some guidance with my OC.
I have it stable, but at a static voltage and frequency.
What I want is to now have the clock speed and voltage scale up and down with load, so that it's cooler on idle, but I just can't seem to get it right. I have speed step and turbo boost enabled, I am set balanced mode in Windows.
I have a 7820X, and my current settings are:
CPU 4.6ghz @ 1.16v vcore
Mesh 3.2ghz @1.1v
RAM 4000mhz @ 1.35v
Am I correct in thinking I need offset mode? I have tried adaptive and it seems to have the same effect.
If so, I think I may be a little confused about the way it works as even when set to + 0.001 the voltage goes through the roof! It hit 1.35v-1.4v instantly on load.
I would have thought it would have been stock volts + the offset, but this doesn't seem to be the case? I have adaptive voltage disabled but the volts still go crazy high.
I have always manually OC'd before with fixed settings, but thought this time I would time a different approach.
I want my CPU vcore to range from stock upto 1.16v, and base frequency to 4.6ghz... but both are locked.
Even if I set Offset or Adaptive mode, the volts or frequency don't scale. Volts just go crazy high and stay there!
What an I doing wrong?
Mesh 3.2ghz @1.1v
RAM 4000mhz @ 1.35v
