Original Post
Alright to start it off, im a completely new to oc'ing a processor.
I started off by using the preset template from my evga board (oc for dummies) it was called or something lol.
It brings mt to 3.2ghz sadly i ran occt for 10mins and i got to 80c.
I have a h50 push/pull setup, in a haf 932.
My i7-930 batch #3001A125. If that makes a difference.
Any help on to getting it stable around 3.2ghz? Be4 i move on any higher.
Alright I have played with the settings myself, I found out my H50 was setup incorrect, and when i did it i messed up the TIM that it came with. Ima order some more to reapply it and put it right this time.
Here is my bios at the moment.
Frequency Control
CPU Clock Ratio ( 21X )
CPU Host Frequency (Mhz) ( 191 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 3061Mhz { 16X } )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 1067Mhz / 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 8 )
tRCD Setting ( 8 )
tRP Setting ( 8 )
tRAS Setting ( 24 )
tRFC Setting ( 71 )
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.32500 )
CPU VTT Voltage ( +100 )
CPU PLL VCore ( 1.650 )
DIMM Voltage ( 1.500 )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( 1.100 )
IOH VCore ( 1.100 )
IOH/ICH I/O Voltage ( 1.050 )
ICH VCore ( Auto )
PWM Frequency ( 1067 KHz )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Disabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 6.400 GT/s )
I did prime95 overnite while i slept and had no errors. I stopped it when i woke up. My temps were average of 67-69c. But core 3,4 were averaging at 60-65c. Which i dont understand.
Any help to get this thing cooler would be great! Thanx
Frequency Control
MCH Strap ( Auto )
Memory Feature
tCL Setting ( 8 )
tRCD Setting ( 8 )
tRP Setting ( 8 )
tRAS Setting ( 24 )
tRFC Setting ( 71 )
Command Rate ( 1T )
Voltage Control
IOH VCore ( 1.100 )
ICH VCore ( Auto )
CPU Feature
