1 - 2 of 2 Posts
Hello all, just finished my AMD rig and was wondering what kind of OC to expect with air cooling..<br><br>
Specs:<br>
ASUS M2N SLI Deluse 570 chipset<br>
Antec TP2 550 PSU<br>
Thermaltake matrix 3000 (fans - 120mm front and 120mm back)<br>
AMD AM2 4200+ (upped FSB ratio 2.1Ghz -> 2.22GHz)<br>
eVGA 7950GT GPU (560/1450 stock)<br>
500Gb SATA Seagate HDD<br>
Dell 20.1 2005 FPW monitor (1680 x 1050)<br>
2GB Corsair 6400 4-4-4-12 DDR2 800 mem<br><br>
Readings using Asus PC probe and Rivatuner (idle):<br>
CPU core - 1.36 - 1.38V<br>
CPU - 34-37 C<br>
Mobo - 36-38 C<br>
GPU - 45-48C<br>
HDD - 32-35C<br>
3D Mk6 score - 5169<br><br>
Do these look normal/optimal? How much juice should I expect out of this config without volt modding or water cooling?<br><br>
thanks in advance
Looking good! I speculate 2.8MHz out of the 4200+. Don't jump up that high at first, start by working up the CPU OC at default voltage first. Watch your full load temps and keep the ceiling @ 50c.<br>
The AM2, like most 939 don't seem to need a lot of voltage, usually below the mid 1.5v range does great on air cooling.<br><br>
OH! A HI and WELCOME to you too <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 2 of 2 Posts
