1 - 20 of 21 Posts
Hello,<br><br>
just signed up as I saw this great site!<br><br>
I oc'd my P4 Prescott 478 from its original 3Ghz to 3.67Ghz without increasing vcore. My question is:<br><br>
1- Did anyone ever clocked 670Mhz (or more) out of a CPU without increasing vcore?<br><br>
2- My ram runs at 400Mhz and the next step of my p4p800-E Deluxe is 500Mhz. Could someone give me Ram timing for 500mhz?<br><br>
3- How can I change my oc multiplier to 14x or less? My Precott has the D0 stepping which is said that it can be run at 14x mplier.<br><br>
4- Does CPU Lock free work for my mb?<br><br>
Here my specs from oc's cpuz:<br><br>
------------------------------------------------------<br>
Processor #1 : Intel(R) Pentium(R) 4 CPU 3.00GHz<br>
Code Name : Prescott<br>
Core stepping : D0<br>
Platform : mPGA-478<br>
Clock speed : 3674.9 MHz<br>
Clock Multiplier : x 15.0<br>
Clock Multiplier : 245.0 MHz<br>
Mainboard : ASUSTeK Computer Inc. P4P800-E<br>
BIOS : American Megatrends Inc. version 1009.003, date 09/05/2005<br>
Chipset : Intel i865P/PE/G/i848P rev. A2<br>
Memory type : DDR-SDRAM<br>
Memory frequency : 245.0 MHz<br>
FSB<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">RAM ratio : 1:1<br>
CAS# : 3.0 clocks<br>
RAS# to CAS# : 4 clocks<br>
RAS# precharge : 4 clocks<br>
TRAS : 8 clocks<br>
TRC : n.a<br>
Idle Timer : n.a<br>
TRDRAM : n.a<br>
TRCD : n.a<br>
Checksum : 1416933377<br><br>
*added* cpuz verified<br><br><a href="http://valid.x86-secret.com/show_oc?id=135887" target="_blank">http://valid.x86-secret.com/show_oc?id=135887</a><br><br><br>
if you wish for more info please let me know<br>
Thanks!<br><br>
Jow
Administrator
<div>Originally Posted by <strong>jowunger</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399160#post1399160"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Hello,<br><br>
TRAS : 8 clocks<br>
TRC : n.a<br>
TRDRAM : n.a<br>
TRCD : n.a<br>
Thanks!<br><br>
Jow</div>
</td>
</tr></table></div>
Generally that CPU is very power hungry so it wouldnt be long until you need to raise the V-core.<br><br>
You cant Change the Multiplier in an Intel Cpu unless its an engineering sample...Sorry
<div>Originally Posted by <strong>ENTERPRISE1701</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399322#post1399322"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Generally that CPU is very power hungry so it wouldnt be long until you need to raise the V-core.<br><br>
You cant Change the Multiplier in an Intel Cpu unless its an engineering sample...Sorry</div>
</td>
</tr></table></div>
<br>
Asus Bios Unlocks P4 Overclocking Potential<br><br>
Patrick Schmid <a href="http://img227.imageshack.us/my.php?image=asusbiosvh8.jpg" target="_blank"><img alt="" src="http://img227.imageshack.us/img227/5209/asusbiosvh8.th.jpg" style="border:0px solid;"></a><br><br>
September 16, 2004 13:00<br><br><br>
Test System<br><br>
Intel Processors (Socket 775)<br>
Model 560 3.60 GHz (12-16/1024 kB)<br><br>
Memory<br><br>
Crucial/Micron Ballistix DDR2-667 (PC5300) 2x 512 MB<br>
Official Timings: CL4-4-4-10<br>
Voltage: 2.0 V<br><br>
Motherboard<br><br>
Socket 775 Platform Asus P5GD2<br>
Intel 925X Chipset<br>
BIOS: ad2p1000.063 pre-release<br><br><br>
Common Hardware<br><br>
Graphics Card ATI Radeon X600 Reference Card, 128 MB PCI Express x16<br><br><br>
Hard Drive<br><br>
Western Digital WD800JB, 80 GB<br>
7.200 rpm, 80 GB per platter, 8 MB Cache<br><br>
Software<br><br>
Intel Chipset Installation Utility Ver. 6.0.1.1002<br>
ATI Graphics Catalyst Version 8.02<br>
DirectX 9.0b<br><br><br>
OS<br><br>
Windows XP Professional<br>
Service Pack 2<br><br><br>
This is how a Pentium 4 Processor 560 at 3.6 GHz should usually be operated.<br><br><a href="http://img227.imageshack.us/my.php?image=locked18jb8.gif" target="_blank"><img alt="" src="http://img227.imageshack.us/img227/4773/locked18jb8.th.gif" style="border:0px solid;"></a><br><br><br>
Here is what CPU-Z outputs after enabling the CPU Lock Free Feature.<br><br><a href="http://img329.imageshack.us/my.php?image=locked14fsb266ml4.gif" target="_blank"><img alt="" src="http://img329.imageshack.us/img329/2525/locked14fsb266ml4.th.gif" style="border:0px solid;"></a><br><br><br>
Asus P5AD2 BIOS Ad2p1000.063<br><br>
All Asus has really done is to offer a BIOS version that enables the user to manually change processor settings from those that the processor otherwise requires. This way, the processor is literally fooled. As a result, it will only boot at multiplier x14 rather then x17 or x18 for the 3.4 and 3.6 GHz versions.<br><br><br><b>Source:</b> <a href="http://www.tomshardware.com/2004/09/16/asus_bios_unlocks_p4_overclocking_potential/page5.html" target="_blank"><b>Tom's Hardware</b></a>
S478 motherboards will not allow unlocked multi's on this chip.<br><br>
The D0 stepping CPU's will do ~4ghz whith a small increase in VCore ~1.50-1.55v (based upon a CPUVID of 1.40v)<br><br>
DDR500 (FSB 250MHz) would equate to 3.75GHz this is eaily obtainable but you may have to use the 5:4 memory divider to keep your memory at DDR400 if it does not overclock very well.
Discussion Starter #5
</td>
</tr></table></div>
Hi,<br><br>
I run it for over a year already without raising vcore <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
<div>Originally Posted by <strong>jowunger</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399439#post1399439"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Hi,<br><br>
I run it for over a year already without raising vcore <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"></div>
</td>
</tr></table></div>
I think he means if you increase the operating frequency any higher than it is now <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #7
<div>Originally Posted by <strong>MjrTom</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399422#post1399422"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">S478 motherboards will not allow unlocked multi's on this chip.<br><br>
DDR500 (FSB 250MHz) would equate to 3.75GHz this is eaily obtainable but you may have to use the 5:4 memory divider to keep your memory at DDR400 if it does not overclock very well.</div>
</td>
</tr></table></div>
I can even get higher then 3.75 but then it is not very stable. At 3.67 it is stable. Sry but what is CPUVID? I guess a bios option but not sure<br><br>
*added*<br><br>
Since i live in Thailand and here the temperature is allways around 30C-35C my rig runs very cool at 42C idle and 49under load. Not want to kill the CPU with higher vcore. Just thought to get the mem to 500Mhz...
Discussion Starter #8
<div>Originally Posted by <strong>MjrTom</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399440#post1399440"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I think he means if you increase the operating frequency any higher than it is now <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"></div>
</td>
</tr></table></div>
oh alright... so do you guys can tell me how it is possible to OC a CPU 675Mhz without raising vcore? I started with an ZX81 about 24 years ago and went all the way to P4. Overclocked many CPU's but never without raising vcore. Or is that a side effect of 'strained silicon' ?
When a batch of CPU's are made the VCore of the CPU is determined. Each processor from the batch is assessed and a voltage assigned to it.<br><br>
Some processors require slightly more voltage than others to operate at the same speed.<br><br>
This means say out of 20 processors rated at 3.0GHz, for instance some will work at 1.40, others need say 1.45v. This voltage requirement is then tagged to the processor so that the motherboard knows what "stock" voltage is.<br><br>
CPU VID = CPU Voltage Identification <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #10
Thanks a lot for all info!
well just to let you know depending on what cooling you have you could easliy push the speed over 4ghz without it going oevr 1.45 voltage as i am overclocking at 4100 and my temp is only 33 'c
Discussion Starter #12
SoulJa I use watercooling from Zahlman which is fantastic.1.45v only? what mainboard do you use>?
someone tell me how to take screenshots and ill take a screen of cpu-z and post it if you arent already using ai booster u might wanna consider somone tell me how to take screens plz
<div>Originally Posted by <strong>soulja</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1401259#post1401259"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">someone tell me how to take screenshots and ill take a screen of cpu-z and post it if you arent already using ai booster u might wanna consider somone tell me how to take screens plz</div>
</td>
</tr></table></div>
Press the "Prt Scr" button on the top right of your keyboard. Now go to Microsoft Paint and paste the screenshot with Ctrl+V. Save this as Jpeg format and upload onto this site <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
<a href="http://img357.imageshack.us/my.php?image=speedgh7.jpg" target="_blank"><img alt="" src="http://img357.imageshack.us/img357/338/speedgh7.th.jpg" style="border:0px solid;"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/8/8f/8fe53e73_vbattach34512.jpeg"><img alt="LL" src="http://cdn.overclock.net/8/8f/525x525px-LL-8fe53e73_vbattach34512.jpeg" style="width:525px;height:328px;"></a>
Discussion Starter #18
AIBooster never works for me. It gives allways a strange error - even the latest version from Asus.<br />
<br />
Did you use Ai-Booster to clock to 4ghz with 1.45v or the bios?
ai booster and i had the same probem as u, get the ai booster from the disc not the one from the interent or you can get it from asus webstie for our motherboard just google it very helpful thats how im overclocking it so much i tried 4200mhz but it crashed
Discussion Starter #20
I wish I would still have that Asus CD - I lost it when I moved to another house - that version from Asus not works - what version is that AI Booster from the Asus CD? Maybe I can find it on the net
1 - 20 of 21 Posts
