After having my E7400 for around 2 years now I have always wanted to o/c and being only 3 months away from my planned upgrade I wanted to breathe some extra speed into it to go with an ATI HD6870 I just purchased. Mainly using it as an HTPC atm.
I am aiming for a stable o/c at between 3.1 - 3.2 if possible with the stock cooler will purchase a Xigmatek S1283 Dark Knight R3 1156/1366 next week though but if I can get the desired result with the stock cooler I will save the cooler for my new build.
Here is what I have done so far after reading through the forums and guides.
C1E Support - Disabled
Max CPUID Value Limit - Disabled
CPU TM Function - Disabled
Execute-Disable Bit Compatibility - Enable ( does this need to be disabled )
Intel (R) SpeedStep (TM) Tech - Disabled
Intel (R) C-STATE Tech - Disabled
AI o/c tuner - manual
FSB Freq. raised to 400
PCI-Express frequency - 100Mhz
CPU Voltage - raised to 1.3500V
FSB Strap to Northbridge - Auto
Ratio CMOS setting - 0.80
DRAM Frequency - DDR2 - 801
DRAM Timing control - Manual - automatically changed to 5-5-5-18 ( not to sure about this one )
After entering all this it booted into Windows fine so decided to run real temp then, Everest and then run a small FFT stress test the cpu temp increased quite considerably to over 90 degrees and then shut down completely which is obviously not a good sign although under the CPU-Z I did notice that I had raised the speed to 3.2 Ghz!
Nearly there but something is not right what do you guys suggest I need to do next?
Any help would be really appreciated as I am at the ends of my knowledge here
