OC temps? confused
253 Views 1 Reply 2 Participants Last post by  XxBeNigNxX
Hey a few people have told me that my cpu (athlon 4000+ x2 brisbane) has very unreliable core temps and that i should use CPU cool or something like tht to monitor the temps of the mobo. but core temp says the core is 43 degrees (i have offset by +10) and CPU cool says 25/26 (all idle btw) i would just like to clarify which is accurate or if they are both wrong because i am very confused thanx.
Specs: athlon 4000+ at 2.5GHz (from 2.1)
GeForce6100SM-M mobo
2 Gig DDR2 800 RAM
1 - 2 of 2 Posts
Sometimes the temps do read right (you have about a 50/50 chance).
1 - 2 of 2 Posts
