1 - 20 of 23 Posts
Well I just dont have the money right now to upgrade AMD dual cores or intel core 2 duos. i want to upgrade my processor...so seeing that places are charging 300 bucks for the skt 754 AMD 3700+ Clawhammer i refuse to buy it from them for that price. so what processor and brand is the best overclocker so i can overclock to the 3700+ speed of 2.4ghz?
why dont you just buy a 3700+ San Diego for 99 bucks?
What's your budget?<br />
<br />
<tr>
</td>
</tr>
</table>
</div>He's on 754.
<tr>
<div>
Originally Posted by <strong>Lozza</strong>
</div>
<div style="font-style:italic">What's your budget?<br />
<br />
<br />
<br />
He's on 754.</div>
</td>
</tr>
</table>
</div><br />
ah. my bad. in that case since you dnont have alot of options, id get a turion if i were you.
Discussion Starter #5
<tr>
<div>
</div>
<br />
<br />
<br />
He's on 754.</div>
</td>
</tr>
</table>
</div><br />
<br />
my budget is really only 100-200 bucks since what im lookin for isnt exactly brand new technology
YOu can OC your NEwcastle up to 220 FSB so you can reach 2200MHz!<br />
Newcastles don´t oc well! If you want more, get a Sempron 64 2800+ or 3100+ or any Turion MT not the ML - series (they suck in ocing like your newcastle) !<br />
What Ram do you have?
hehehe...3400+...or a 2800+
well for less than $170 you can upgrade to a opty 144 venus for $77 at new egg and a 939 motherboard heres an example <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813136163" target="_blank">http://www.newegg.com/Product/Produc...82E16813136163</a><br />
you can upgrade pretty well.. and that opty has a good chance of seeing 2.7 to 3.0 ghz depending on the stepping you get.
<tr>
<div>
Originally Posted by <strong>The Specialist</strong>
</div>
<div style="font-style:italic">YOu can OC your NEwcastle up to 220 FSB so you can reach 2200MHz!<br />
What Ram do you have?</div>
</td>
</tr>
</table>
</div>LISTEN TO THIS GUY<img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /> <br />
Click on the <b><font size="5">2.737</font></b> in my sig junior
<tr>
<div>
Originally Posted by <strong>PROBN4LYFE</strong>
</div>
<div style="font-style:italic">LISTEN TO THIS GUY<img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /> <br />
Click on the <b><font size="5">2.737</font></b> in my sig junior</div>
</td>
</tr>
</table>
</div>That OC is good! But not every Chip can do that! I was talking about speeds he can reach and the speeds in his dreams or in your sig ...
Discussion Starter #11
<tr>
<div>
</div>
<div style="font-style:italic">That OC is good! But not every Chip can do that! I was talking about speeds he can reach and the speeds in his dreams or in your sig ...</div>
</td>
</tr>
</table>
</div><br />
ive already gotten my 3000+ newcastle to 2.23ghz right now on stock heatsink..but i dont even notice it with the games i'm running..they need more juice!<br />
<br />
<br />
could i get 2.7ghz with a new heatsink? if so which one should i look into getting?
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835185027" target="_blank">This</a> one is great! <br />
<br />
You have the same Mobo and GFX like me <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
naw man scythe is too new and they need to work on there fans ,they are slow and break easy """Cons: The stack fan broke as soon as I laid it on my dining room table just after opening the box.""" thats a review from the link u gave
Get the Athlon 64 3000+ socket 754. You should be able to get it to 2.4GHZ. I have the same processor but its socket 939 and i have mine at 2.43GHZ.
I have a 754 pin Settup and a 3000+ Venice at 2.5Ghz 250 FSB with my value ram running at 500mhz <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
The 3000+ Venice is cheap too <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Discussion Starter #16
<tr>
<div>
Originally Posted by <strong>Brodman</strong>
</div>
<div style="font-style:italic">I have a 754 pin Settup and a 3000+ Venice at 2.5Ghz 250 FSB with my value ram running at 500mhz <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
The 3000+ Venice is cheap too <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
so your venice at 2.5ghz is equivalent to what processor at stock? like a 3400+ or somethin?
Some options...<br />
1. A good FHS on the cheep that works good for either 754 or 939.<br />
<a href="http://www.provantage.com/arctic-acfzp64~7ARCT002.htm" target="_blank">http://www.provantage.com/arctic-acfzp64~7ARCT002.htm</a><br />
Use that to OC your current set up further or...<br />
<br />
Get a " ADA3700<b>BN</b>BOX" 3700+ @ about $97 which should OCwell. do NOT get the " ADA3700<b>CF</b>BOX! <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103539" target="_blank">http://www.newegg.com/Product/Produc...82E16819103539</a><br />
Pair that up with a Biostar <b>T </b>Force 6100 939 for about $70 and you'll do well. <br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813138264" target="_blank">http://www.newegg.com/Product/Produc...82E16813138264</a><br />
You will have to look elsewhere, it's out of stock <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Normally you can say if you oc a (for example) 3000+ from stock 2000MHz to 2500MHz you have a 500MHz gain so double it and add the 1000 to your rating (3000 + 1000 = 4000) so get 4000+ rating!<br />
<br />
Please correct me if im wrong!
Well an 3400+ has a speed of 2.4ghz with a L2 cache of 512Kb<br><br>
An 3700+ has a speed of 2.4Ghz but with a L2 cache of 1Mb<br><br>
So mines running a little better that the 3400+ becouse the 3000+ only has a L2 512Kb cache
<div>Originally Posted by <strong>saywhuut</strong></div>
<div style="font-style:italic;">Well I just dont have the money right now to upgrade AMD dual cores or intel core 2 duos. i want to upgrade my processor...so seeing that places are charging 300 bucks for the skt 754 AMD 3700+ Clawhammer i refuse to buy it from them for that price. so what processor and brand is the best overclocker so i can overclock to the 3700+ speed of 2.4ghz?</div>
</td>
</tr></table></div>
As for the upgrade for under $100.00 you would be best served with the 3000+Venice 754 for $67.00 <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103605" target="_blank"><b>here</b></a><br>
Or for a jump up in price to $155.00 for a Turion 64 MT32 <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819103007" target="_blank"><b>here</b></a>
1 - 20 of 23 Posts
