Some more information from source that is included in OC3D:
Source: http://www.overclock3d.net/articles/gpu_displays/nvidia_pascal_titan_rumored_to_be_coming_as_early_as_april/1
Nvidia's upcoming Pascal GPUs are now rumored to be coming to market as early as April, starting off with a Pascal Titan-esque GPU, with lower end models coming later.
The high end models are expected to using the GP100 GPU core, which is built on TSMC 16nm process and use HBM memory, though right now capacities are yet to be confirmed, but current rumors suggest a maximum VRAM capacity of 32GB.
At around June of this year Nvidia are rumored to be launching their GP104 core GPUs, which are rumored to be using GDDR5X memory and not HBM, this will make up the GTX 1080 and GTX 1070, if Nvidia continue to use their current naming scheme.
The GTX 1080 is expected to have performance that is similar to the GTX 980Ti or Titan X, but come in with a lower TDP and thermals.
Source 2: http://techfrag.com/2016/01/25/nvidia-2014-2017-gpu-roadmap-pascal-titan-gp100-to-debut-in-april-gtx-1080-in-june-and-volta-in-2017/Further, the GP104 will have a die size of around 300 to 350 mm² as compared to the GM204's 398 mm², while the GP100 aka the Big Pascal will come with a little more 450 mm². Moreover, the chip is rumored to feature 32GB of VRAM and nearly 17 billion transistors in a relatively smaller packing. The flagship Pascal GPUs are based on the 16nm FinFET process and are said to use the next generation High Bandwidth Memory, or HBM2, standard.
As for the unveiling, the Titan grade products based on the GP100 are expected to be announced in April, with the downgrade version to debut in June 2017 (1080 Ti). On the other hand, the GP104 based series, allegedly called the GeForce GTX 1080, and its scaled down version GTX 1070 will be unveiled in June this year, just before or after COMPUTEX.
