Tried to find consistent information on max heat for a Intel Prescott. No luck so, thought I'd drag the subject up again....
3.2ghz with a xp-90. It runs a little under 50C until room temps go up. The CPU is going as high as 55C with the CPU running at 100% and oc'd to a little over 4ghz. Fans are running about as fast/loud as I care to run them.
Strongly concidering water cooling so, this is kind of leading up to a purchasing decision (separate subject)
Thanks....
Thanks....
