1 - 6 of 6 Posts
Anyone know of any tips or tricks with this card? Mine doesn't oc that well?!?!? And for some reason I can't get riva to work and oc my speeds, i have to use powerstrip.????
Try using coolbits, which is essentially the nVidia drivers. You can find that <a href="http://www.softpedia.com/get/Tweak/Video-Tweak/GeForce-Overclocking-CoolBits-Reg.shtml" target="_blank">here</a>.<br />
Also, I would get aftermarket cooling if you want to get some good clocks, and if your card only has a heatsink, rig a fan up to it.
What percentage overclock can you expect from a 7600GS? On average? If the Stock temps are 41C underful load
Administrator
You can get a Good overclock from a 7600GS especially at those load temps you have som good overclocking headroom. I would use Coolbits to overclock your card mate. Also there are some V-mods for that card .<br><br>
V-mod : <a href="http://forums.guru3d.com/showthread.php?threadid=180831" target="_blank">http://forums.guru3d.com/showthread.php?threadid=180831</a><br><br>
Coolbits :<a href="http://www.overclockers.com.au/techstuff/a_coolbits/" target="_blank">http://www.overclockers.com.au/techstuff/a_coolbits/</a>
So about what Percentage increase could I expect? Average overclock do you know? 20% 30%?
1 - 6 of 6 Posts
