1 - 5 of 5 Posts
hi i got this thinkpad and would like to oc it,what program do i use cuz i dont see anithing in the bios<br />
i rebuild this laptop and notest that the termal paist was dry and crusted up<br />
so i put AS5 and that should help i think<br />
plz help me oc it <br />
<br />
its a p3 e 1Ghz bga2<br />
256MB kingston sdram part number is kvr133x64sc3/256<br />
MB is ibm 265630u<br />
chipset is ALI aladdin pro 2 southbridge ali m1533
was it a computer built at a store, if so u cant oc it to the best of my knoledge
try clockgen, it can be done. All my dell laps are oc'ed by the same program. You need to find out the ICS# for the chipset.
Reactions: nemesis975
DO NOT overclock a laptop, ever! It gets too hot and causes too many problems.
Discussion Starter #5
um im well aware of that ty for ur careness but 10 of fsb increase wont hurt <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /> and i cant find the ICS# for some reason<br />
<br />
here look<br><a href="http://assets.overclock.net.s3.amazonaws.com/7/7a/7a1e2267_vbattach33299.bmp"><img src="http://www.overclock.net/image/id/616999/width/525/height/525/flags/LL"></a>
1 - 5 of 5 Posts
