1 - 3 of 3 Posts
well today iv been getting the same bsod 0x00000124
and this is my bios settings
any help?
dvanced CPU Features:
CPU Clock Ratio ................................ [20 ]
Intel(R) Turbo Boost Tech ................. [Disable]
CPU Cores Enabled .......................... [All]
CPU Multi Threading ..........................[Enable]
CPU Enhanced Halt (C1E) ................. [Disable]
C3/C6/C7 State Support ................... [Disable]
CPU Thermal Monitor ........................ [Disabled]
CPU EIST Function ............................ [Disable]
Uncore & QPI Features:
QPI Link Speed ..............................[x36] 7.2GHz
Uncore Frequency ..........................[x18] 3600 MHz
Isonchronous Frequency ...............[Enable]
Standard Clock Control:
Base Clock (BCLK) Control .................. [Enable]
BCLK Frequency (MHz) .........................[200]
Extreme memory profiler........................[Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[800]
PCI Express Clock Drive ................ [900]
CPU Clock Skew ............................ [0]
IOH Clock Skew ............................. [0]
Advanced DRAM Features:
Performance Enhance .......................... [Standard]
Extreme Memory Profile (X.M.P) ........... [Disable]
System Memory Multiplier (SPD) ........... [ 8]
DRAM Timing Selectable (SPD) ............. [Quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ..................[9]
tRCD ......................................[9]
tRP ........................................[9]
tRAS ......................................[24]
CR..........................................[2]
B2B........................................[-]
Advanced Voltage Control:
CPU Intel Core i7 920 D0 Stepping
Load Line Calibration .................... [Standard]
CPU Vcore ......................................[1.312]
QPI/VTT Voltage 1.150v .................[1.335]
CPU PLL 1.800v ..............................[1.80]
PCIE 1.500v ...................................[AUTO]
QPI PLL 1.100v ..............................[AUTO]
IOH Core 1.100v ............................[AUTO]
ICH I/O 1.500v ...............................[AUTO]
ICH Core 1.1v ................................[AUTO]
DRAM
DRAM Voltage 1.500v .............. [1.64]
That bsod code means not enough QPI/VTT voltage or too much.
1 - 3 of 3 Posts
