1 - 2 of 2 Posts
My rig:
ASUS M5A78L-MXLPLUS
FX4100 Bulldozer 3.6ghz (Current)
Patriot G Series 2x2 DDR3 1600mhz 9-9-9-24
Radean HD 4890
Antec TP3 650
OCZ Agility2
My ram is running @ 1033 -_-
Need to get some juice out of this, also I am seeing some artifacts out of the GPU with the latest drivers.
1. Your motherboard is 3+1 phase rated for 95W TDP
Running your FX4100 overclocked will increase its TDP, and the motherboard will start throttling (downclocking) to prevent from overheating.
I suggest you just do a mild overclock around 200-500 mhz to avoid overheating or put some heatsinks on your mosfets.
READ THIS: http://www.overclock.net/t/943109/about-vrms-mosfets-motherboard-safety-with-125w-tdp-processors
2. Did you overclock your HD4890? artifacts usually means overheating. Check its temperature while gaming
3. Your RAM is running at 1033? is that a typo and you meant 1333?
1 - 2 of 2 Posts
